09-06-2023 05:15 PM
Hello,
I have a Canon iR-ADV 4525 copier, which I've set up correctly to use SMTP to send "Scan and Send" documents to addresses in the "Personal Address List." Settings are exactly the same as another copier at a different site with a functional copier. When I "Check SMTP Connection," I get a "Connection to the server was successful." result.
When I try to scan and send, however, nothing ever gets sent. I've checked the Send Log, and here is an example of a failed attempt:
Job No. (Return Job No.) | Result | Start Time | End Time | Department ID | Job Type | Destination | User Name | File Name | Originals | Original Pages | Send Pages | TX File Size (KB) | Communication Mode | End Code |
8 | NG | 9/6/2023 12:44 | 9/6/2023 12:45 | ****@*****.com | ----- | 1 | 1 | 0 | 0 | #801 |
My research seems to indicate that an End Code "#801" might mean an SMTP timeout occurred. Is this correct?
If so, what should be my next steps?
Thanks for your replies and help..!
09-06-2023 05:20 PM
Welcome to the forum!
While our forum community members are welcome to chime in, Canon does not provide direct support for imageRUNNER series products. Instead, your dealer will be able to help you. If you don't have a dealer and you're in the United States, please call us at 1-800-385-2155 and we will be happy to provide you with the names of dealers in your area.
If you're outside the USA, visit http://global.canon and choose your country or region from the map for local support.
Thank you
09-06-2023 05:41 PM
Thanks, Tiffany..!
