imageRUNNER ADVANCE DX C257iF VOIP Compatibility
JM_PFD
Will the C257iF work with Voip?
3 REPLIES 3
Moderator
Moderator
Hi, JM_PFD!
Thanks for posting! While our forum community members are welcome to chime in, Canon does not provide direct support for imageRUNNER series products. Instead, your dealer will be able to help you! If you don't have a dealer and you're in the United States, please call us at 1-800-OK-CANON (1-800-652-2666) and we will be happy to provide you with the names of dealers in your area.
If you're outside the USA, visit http://global.canon and choose your country or region from the map for local support.
We hope this helps!
Are you asking about Fax capability?  If so, the answer is no.  Fax requires an analog phone line.
If you aren't asking about Fax, then you'll need to tell us what it is you are trying to do?
JM_PFD
Fax, yes. Thx.
