imagePROGRAF TC-20: NOT printing in color anymore, ink full, no error messages
LCARON
Please help! I am a teacher, and I purchased the TC-20 to print posters at home for my classroom.  Ive had the printer for a little more than a year with minimal issues besides some colors being off and some feed/jamming.  I tried to print yesterday and no colors are printing, only B&W. I have used the "clean printer heads' function and done test patterns 5x with no success.  I did 2 deep cleans and printed the test pattern- still no color.  I even made sure the software was up to date and printer heads were aligned. Nothing is working.  PLEASE HELP! I need this for work and I don't know what to do bc they don't seem to offer service visits and the call center is "closed" each time I've tried it.  There seems to be no customer service online at all.  I spent close to a thousand dollars on this and Im getting ZERO support.  Someone please help!  #imagePROGRAF TC-20
4 REPLIES 4
Tiffany
Moderator
Moderator
Welcome to the forum!
The forum is not intended for immediate support. If this is a time-sensitive matter, click HERE search our knowledge base or find additional support options HERE
Again, Canon proves how helpful they are. No solution no help, just “this forum is not for support”. Great, thanks so much.
Saduval
Has this issue been resolved? Is so how!??Also a teacher and for some reason it stopped printing colors accurately.
chrissolve3d
Its a little bit late to help but for future users with the same problem. If the following happens. Nozzle check that is unsatisfactory - clean - nozzle check - worse result - deep clean - worse result (colour completely dissapearing), don't keep cleaning.!!! It will get worse. You may have not used your printer for a while and the ink has dried on the head. What you need to do is a complete a print head flush. First make sure your ink tanks are at least 1/3 full. This process uses 10% of your very expensive ink. Also, you need to ensure that your Maintenance cartridge MC-32 is not already full. If it is, I would replace it as I just managed to complete the flush before my maintenance cartridge warning came up. When you have established this is OK to proceed go into the maintenance menu and look for 'Replace Ink in Print Head'. This process takes around 9 mins and must not be interrupted. When completed you need to not touch anything for a minimum of 1.5 - 2 hours. I actually left it on stand by overnight for the following reason. When flushing, the process generates a lot of air bubbles in the ink tanks. If you try to print at this stage you will continue to get a poor nozzle check result due to this air content. If you leave for longer than 2 hours this will allow the air to rise and purge from the ink. The next day my nozzle check was perfect.  Following the maintenance instructions Exactly and a little patience and you stand a very good chance of getting your colours back in full. Rather than Canons unfathomable, poorly compiled instruction manual I resorted to chat GPT for the first time in my life and it was spot on!  I got all of the full colours back like new. If this doesn't work you probably need a new print head but I suspect this process will do the trick. Good Luck and Hope it helps.
