05-18-2021
06:30 AM
10:54 AM
hi,
I'm trying to do an unattended installation of PCL driver. it worked on an older version of the driver, but last version is not working with the exact same command:
rundll32 printui.dll,PrintUIEntry /b "PrinterTest1" /x /n "zz" /if /f CNP60MA64.INF /r "IP_192.168.1.102" /m "Canon Generic Plus PCL6"
this is the file list of my old version:
aussdrv.dl_ CanGPX5.up_ CanGPX5.xp_ cnp60403.dl_ cnp605A64.inf cnp605.cat cnp60m.dl_ cnp60mui.dl_ cnp615.ch_ cnpxcm32.dl_ cnxdias2.dl_ cnxp0log.dl_ cnxpcf32.dl_ cnxpcp32.dl_ cnxptn32.dl_ cpc10d.ex_ cpc10e.dl_ cpc10q.ex_ cpc10s.dl_ cpc10v.ex_ cpc1CA.ch_ cpc1CA.dl_ DISK1 ucs32p.dl_
and this is the file list of the unpacked PCL6_Driver_V240:
CNP60MA64.INF cnp60m.cat gppcl6.cab
obviously the format changed so I need to know how can I perform a silent install with this new version.
05-18-2021 08:09 AM
Hi, muzzol!
So that the Community can help you better, we need to know exactly which Canon printer model you're using. That, and any other details you'd like to give will help the Community better understand your issue!
Thanks and have a great day!
05-18-2021 09:04 AM
currently I'm trying to install a Canon iR-ADV C5235, but I've been using the generic PCL for quite some time with a lot of diferent models without any problems.
In fact I need to upgrade because the option of not using department ID for BW jobs. If it wasn't for that I would keep old version that works ok for unattended installs.
05-18-2021 09:07 AM
While our Forum Community members are welcome to chime in, Canon does not provide direct support for imageRUNNER series products, but your dealer will be able to help you!
If you don't have a dealer, please visit https://Canon.us/l9jud to locate the names of dealers who are in your area!
05-18-2021 10:51 AM
Muzzol,
Check this out:
PrinterLogic - Products - Canon Solutions America
05-18-2021 02:39 PM
thanks for your responses, I'll take a look.
anyway this is not related to a single model, I also have some LBP and MF models, so I would like a specific answer:
how can I perform an unattended/silent install of current Generic PCL driver?
05-26-2021
07:09 AM
11:09 AM
Stephen
OK, as no one is jumping in here I'll give the proper answer in case any other sysadmin faces the same problem.
short answer is: dont' use printui, use vbs scripts for installing drivers.
long answer is that installer changed and you can't use old method (RUNDLL32.EXE PRINTUI.DLL,PrintUIEntry)
instead you need to use cscripts located at C:\Windows\System32\Printing_Admin_Scripts\en-US\
that's only for drivers, not for installing printers/queues.
I'll give an example.
for this driver: GPlus_PCL6_Driver_V240_32_64_00.exe
you need to use unpack it and use the Driver subdir (you don't need the rest)
and then use a command like this (assuming your unpacked subdir is in c:\temp)
cscript "C:\Windows\System32\Printing_Admin_Scripts\en-US\prndrvr.vbs" -a -m "Canon Generic Plus PCL6" -i "C:\temp\Driver\CNP60MA64.INF" -h "C:\temp\Driver" -v 3
now you have the driver installed and you can use printui if you want because driver is already on the system so it doesn't really matter if you use the /u parameter because it will use the one installed.
so you need to do something like this:
rundll32 printui.dll,PrintUIEntry /b "Printer1" /x /n "zz" /if /f "CNP60MA64.INF" /l "C:\temp\Driver" /r "http://cups3.imasmallorca.net:631/printers/CANON_IRADV_c5235i_Informatica" /m "Canon Generic Plus PCL6" /u
if you want you can use vbs scripts for adding/removing printers, is just that I already have all my scripts done for my setup so I keep using them.
take a look here if you prefer to use Prnmngr.vbs : https://docs.microsoft.com/en-us/previous-versions/windows/it-pro/windows-server-2012-R2-and-2012/cc...)
now there's another problem here about configuring default settings.
I won't enter in lot of details here, but it can be done with this commands:
configure settings and then execute this to store them:
rundll32.exe PRINTUI.DLL,PrintUIEntry /Ss /n “Printer1” /a “C:\temp\PrinterConf1.dat”
now install another printer in another machine and use this command to import saved settings:
rundll32.exe PRINTUI.DLL,PrintUIEntry /Sr /n "Printer1" /a “C:\temp\PrinterConf1.dat” /q r p
if you need more info, please don't hesitate to ask me here or reach me at [removed email]
happy configuration!!!
05-22-2023 01:23 AM
i made an account just to thank you for taking the time to put this information together
silent canon printer installation should not be so difficult
do you happen to have any suggestions for silent installing the scanner drivers/software for a MF printer? i've dug around in the .msi files with Orca, and tried to find silent flags buried in the .exe files, but so far no luck. i never expected so much trouble 😵
05-24-2023 04:48 AM
hi JR!
thanks for taking your time to write that kind response 🙂
regarding your scanner installer, every packages is different so is hard to help you without the specific installer in hand.
that being said, msi are usually easy to install unnattended. something like:
msiexec /i C:\setup.msi /qn /norestart
should help you
by the way, for some strange reason admins are blocking my email. if you want to contact me use my username and add the most common domain for mails in the world and you got it.
canon got a strange concept of community: not giving answers, blocking communication between users, relying you to enterprise-only support...
07-23-2024 04:11 PM - edited 07-23-2024 04:36 PM
Hi muzzol,
When I am using below given script to install Canon Generic Plus PCL6 driver, I am getting error message "Unable to add printer driver Canon Generic Plus PCL6 Win32 error code 87" . Also if you can help me out to deploy this driver via Intune (Win32). Please give the response
