10-23-2023 07:10 PM
Hello,
we are getting soft banding on dark grey areas (Please see attached image).
I already did:
1. Firmware update;
2. Disassembled cover panels and checked for air bubbles;
3. Replaced print heads;
4. Increased Ink Dry time up to 3-9 sec;
5. Drilled holes in grey and black ink cartridges (so there is no vacuum);
6. Cleaned/washed with ultrasonic all purge pads.
7. Nozzle check, feed adjustment, head alignment;
All that didn't help.
We are having the same issue on both new printers((
11-03-2023 07:43 PM
Any ideas?
11-30-2023 07:33 PM
up
12-19-2023 11:52 AM
up
12-19-2023 11:54 AM
Thanks for being part of the conversation, ukrsonic!
This community is designed for your fellow Canon owners to help each other out with any problems they may encounter. If this is a time-sensitive matter, click HERE search our knowledge base or register your Canon gear HERE to access additional support options.
Thanks and have a great day!
01-23-2024 03:37 PM
The problem is still present
03-06-2024 06:51 PM
up
03-28-2024 02:28 PM
up
03-28-2024 02:32 PM
Hi again! As we've mentioned before, the Canon Community Forum isn't always the fastest way to get help. If you still need help with your imagePROGRAF printers after all this time and if you're based in the United States, please call our support line at 1-800-OK-CANON (1-800-652-2666). We're open Monday through Friday.
And if you're not in the United States, please contact the Canon company that serves your country directly. You can look them up HERE.
We hope to help you soon!
09-12-2024 05:07 AM
I'm curious to know if you got this sorted out in the end? I'm having similar issues posted in this thread: https://community.usa.canon.com/t5/Production-Printing/Banding-on-new-Pro-2600/td-p/499973
