04-06-2023
04:27 AM
10:35 AM
Hi, I need .inf file for my cp1300 because I am already install on windows10, and try looking for that inf file but there is no directory or inf file contain canon printer
04-06-2023 08:31 AM
Hi, cecep! If you're getting an error message regarding a missing file, it might be easiest to simply reinstall everything. You can download everything you need for your SELPHY CP1300 for free right here. Hope this helps!
04-08-2023 01:38 PM
Iam download again and try to install the installation process is success, and the printer is working fine. I need this extracted file to install driver into ultrasound machine thats wahy I need this file, can you give me or send me the file not exe file? thanks
04-08-2023 04:29 PM
You should be able to use winzip or 7zip to extract the contents of an .exe.
04-09-2023 11:38 AM
This is the contain of cp1300 .exe driver, try to add printer to my ultrasound there is no information contain for the device{printer}.
Iam still need the full extracted driver, pls help, thanks
07-12-2024 04:05 PM
you can get full extract at %temp% (canonUPW) after you installed exe file, you can copy CanonUPW and then add printer at your ultrasound
07-12-2024 04:54 PM
It's likely this was solved or abandoned. There has been no activity on this thread for over a year.
