07-16-2024
01:44 AM
08:14 AM
Stephen
I have a Windows 11 notebook and a new imageClass MF455dw. I've downloaded the main driver [Windows 64bit] Generic Plus UFR II Printer Driver V3.00. I can't find a specific scan driver so I am assuming that is part of the driver already downloaded. the MF Scan Utility has also been downloaded.
Upon attempting to open the MF Scan Utility, I get the following error, "A scanner driver supporting this software is not installed. Install it and train again."
I have uninstalled/reinstalled the driver and scan utility and still no success. Suggestions?
By the way if it matters, I can print.
07-16-2024 10:43 AM
You are actually missing the scanner driver. (Not serious).
You only need 2 drivers to get 100% function from the device. I would recommend this. Download the MF Drivers Package (1) and then Scanner driver (2).
1. https://pdisp01.c-wss.com/gdl/WWUFORedirectTarget.do?id=MDEwMDAxMTIxNzAx&cmp=ABR&lang=EN
2. https://pdisp01.c-wss.com/gdl/WWUFORedirectTarget.do?id=MDIwMDAwNjg2NTAz&cmp=ABR&lang=EN
Remove the Printer from Settings, then uninstall the printer drivers. Important restart your computer.
Now run the #1 download. Then #2
You will now have the MF Drivers (which includes the UFRII) standalone printer driver you installed earlier+ ScanGear. The MF Scan Utility is the second (scanning) driver you are currently missing. The 2 together are all you need.
If you are using Wireless, you can also update the printer's firmware by scrolling through the Control Panel on the LCD. Look for a little printer device icon with the blue arrow aiming down. Tap it, and wait. It takes about 4 minutes. As of today, this is v1.0.4. Don't send any jobs to the printer until the update completes. I'm running this on both of my printers. All are working great.
~R5 C (1.0.7.1) ~RF Trinity, ~RF 100 Macro, ~RF 100~400, ~RF 100~500, +RF 1.4x TC, +Canon Control Ring, BG-R10, 430EX III-RT ~DxO PhotoLab Elite ~DaVinci Resolve ~Windows11 Pro ~ImageClass MF644Cdw/MF656Cdw ~Pixel 8
~CarePaks Are Worth It
07-16-2024 10:43 AM
07-16-2024 07:23 PM
Thanks Rick - this helped.
07-17-2024 04:22 PM
Thank you for your feedback. Enjoy the printer 🙂
