Scanner Canon i-SENSYS MF651Cw doesn´t working MF scan utility
IT_support
I have technical case open with Canon, but they don´t find solution yet. The printer is Canon i-SENSYS MF651Cw with Operating System , Windows 11 Home 22H2. and when I install MF Scan Utility appear the following error:
Could you help me to solve this issue?
Thanks in advance.
7 REPLIES 7
Arthur
Moderator
Moderator
Welcome to The Canon Community, and thank you for your inquiry!
We appreciate your participation, however, we need to let you know that the Canon Community is hosted and moderated within the United States by Canon USA. We are only able to provide support for Canon products manufactured for and used within the US market.
If you live outside the United States, please CLICK HERE and select your country or region for your support needs.
You're welcome to discuss Canon products sold outside of the United States, but please be aware that you will not receive support directly from Canon USA.
IT_support
Dear,
Thanks for your quickly reply. In this case the product was bought in USA and I would like to know any solution.
Could you help me?
Hello,
The i-SENSYS MF651Cw is a European-exclusive model not sold in the US.
Can you please verify the model information from the physical unit? It's usually on the top or front panel.
For support in the United States, call 1-800-OK-CANON (800-652-2666) weekdays from 9 a.m. to 6 p.m. (ET).
Outside the US, visit https://global.canon/en/support to find support options in your country.
normadel
Instead of trying to use the MF Scan Utility at all (I gave up on it myself), go to the Microsoft Store and install the Windows Scan app. It is capable and uncomplicated. It sees USB and network scanners just fine.
Thanks for your quickly reply. I checked your propose and It scans one sheet, but if I want to scan many sheets at once, Do you help me in this case?
IT_support
It has another drawback. You know that there are two ways to scan. Flatbed and feeder. From the feeder it does not scan well, it leaves the pages cut off.
I called Support Spain support but I haven´t solution to this problem from Spain. Who can help me?
