05-25-2025
11:50 AM
10:16 AM
Using windows 11 home and have the MF753cdw printer/fax/scanner. I have no issues installing the printer and fax drivers but cannot get the scanner driver to install. I have tried turning of the firewall to install and no luck. Depending on how I get to the driver I get an error that just says install failed or I get an error that says install error due to port error. I have also tried to connect via usb cord and wi-fi.
05-29-2025 12:48 PM - edited 05-29-2025 12:49 PM
I'm having the exact same problem, only on Windows 10 Pro. I've even tried logging on as the domain admin and the darned scanner driver will NOT install.
