11-29-2020
06:40 PM
08:34 AM
James_C
I have been struggling to get this printer to work consistently on my network from my MACs. Most of the times when I try to print, I get an error.
Opening the Settings --> Printers and Scanners --> Canon 644c,
The banner says that the printer is offline.
Under the print job I get the message Priner - Unable to find printer
None of the macs can consistently print using the print function.
Anyone else face the same problem?
04-18-2021 10:51 PM
..working until you lose power again. Consider making the IP address as static as suggested.
06-07-2021 04:01 PM
Hello SGUF Fan,
If the Mac is connected to the network via ethernet and you can scan but can't print, it will usually point to the driver being used for the printer connection. I would suggest starting by downloading the recommended driver for the MF743Cdw using the link provided HERE.
Once the drivers has been installed, you can remove the printer from the printers and scanners list using the - at the bottom of the printer list. Once it has been removed, you can click the + to add the printer back.
When adding the printer back, make sure the USE box near the add button is not set to the Mac's generic airprint connection. You can click the dropdown and select the driver that has the printers name attached to it. If it does not appear, you can click on select software and search for your printer model number. Once it has been added using the proper driver, the connection should be more reliable.
06-07-2021 04:15 PM
Thank you for your response. I was able to delete and re-add the printer much like you describe.
10-25-2021 10:31 PM
Hi Canon support,
Why don't set up an easy to find trouble shooting page with clear instructions for offline printers, with photos and step by step instructions or does a page like this exist? Thanks!
10-25-2021 10:32 PM
Everyone is asking the same question and then you answer each time, would be better use of time for everyone. Thanks!
09-15-2023 01:18 PM
I've had this problem several times over the last few years on my MF644Cdw; it happens every time the power goes out, or I upgrade my network. I've tried EVERYTHING listed above, wirelessly and wired and I've purchased multiple replacement printer cables thinking they were the issue. Some of the options worked after being on the phone with tech support for an hour or more.
This time, I factory reset my Mac (using OS 10.15.7) and I watched YouTube video imageCLASS Multifunction Five Line Display Wireless Setup Video for Macintosh (MF113w) which is linked on the Canon website. I noticed nothing different from the steps I'd made previously until 5:13-5:33. In the past; I didn't Add my printer because it automatically populated so I didn't have the opportunity to highlight my printer or select my printer driver from the Use dropdown. This was the simple answer to my problem. My drivers had been downloaded but weren't in use causing my printer to show as offline.
The Solution: System Preferences/Printers & Scanners
I've likely completed this step with tech support on the phone and don't recall, but it worked for me this time. I hope it helps you.
09-17-2023 02:36 PM
Thanks for the details!
01-22-2024 10:15 AM - edited 01-22-2024 11:37 AM
SOLUTION:
What made the whole problem go away is that I did this:
1. Setup the printer with a static IP address (don't use DHCP). It doesn't matter if you're printing wirelessly or have it connected via ethernet. This is critical because you'll need the static IP address later in these steps. After you have done so, restart the printer and ensure that it's using the static IP address.
2. Download the latest drivers from Canon's website. Install them. (YMMV whether or not this will all work when trying to connect via AirPrint from your Mac, I used Canon's drivers.)
3. Remove the printer from MacOS. Remove the Fax too if you have an entry for that. Reboot if you want to, never hurts after doing something like this.
4. Add the printer. DO NOT use the first tab where it auto-detects and finds it via Bonjour. Instead go to the 2nd tab (that looks like a globe) and add it using the IP address that you established in the previous step. IPP is the default protocol, keep it. Then you MUST select in the "Use" field the printer driver you installed in the previous step.
5. If possible, I'd also recommend not using WiFi as the way to access the printer on your network, use an ethernet cable to connect the printer directly to the router. (I have not done this but it is always recommended!)
6. You can also configure the printer's WiFi settings (if you didn't listen to me in step 5) to disable the printer's WiFi power management setting (turn it off), that was highly recommended in another post and as far as I can tell it couldn't hurt.
As far as I can tell, step 4 is important because it tells the driver "always find the printer at this IP address" and bam, even when it's asleep, I can print to it from my Mac, even via WiFi, when I couldn't before.
This raises the question "what about my iPhones and iPads?" where you don't actually install any print drivers and it relies on AirPrint? I don't know, I haven't toyed around with that just yet. But these steps got me printing even after the printer went to sleep and would otherwise have shown as offline. I hope this works for you.
07-06-2024 04:35 PM
I've suffered with this problem with our Canon MF642C/643C/644C for at least a year. 5 Macs, all running the latest OS. 1 MacMini (2023), 2 MacBook Pros (a 13 inch and a 16 inch, M1 and M3 respectively) and two MacBook Airs (M1 chip)
Reinstalling the printer (became a daily routine, sometimes worse than that.)
My fix:
Here are some resources:
My printer works for all our Macs as well as our iPads and iPhones.
FINALLY, Success.
07-07-2024 03:47 PM
Thanks! This is great information.
