03-08-2020 07:36 PM - last edited on 03-17-2023 02:17 PM by Danny
I have a MF644C and about every week or so the Airprint name changes. This prevents me from printing via my Macbook Pro until I delete and re-add the printer. Under "Settings/Registration: Preferences: Network Settings > AirPrint Settings" I originally set the Printer Name to "Canon MF644C", then it suddenly changed to "Canon MF644C (dd:ed:b5)" and most recently changed to "Canon MF644C (dd:ed:b5) (dd:ed:b5) (7)". I really don't care what the name is, but why does it keep changing?
06-12-2020 03:56 AM
Same here. The suggested solutions don't help. The mDNS name keeps changing automatically (it gets something like "(ab:cd:..) added to its name), which causes the printer to not be accessible any longer from our Macs.
Removing and re-adding the printer is only a temporary solution. With the next (automatic) mDNS name change, the problem starts fresh.
Disabling mDNS is not an option here.
Why does the mDNS name in the printer change automatically? This is not a driver issue. The printer should keep its assigned mDNS name, but it doesn't.
08-06-2020 04:50 AM
I'm pretty sure the following is happening:
Step 3 is actually quite senible, I think. If you have multiple identical printers and they are not switched on at the same time, you still do not want them to have the same Bonjour name. So allowing my Mac to tell the printer that that generic name was previously seen so the 'new' printer better pick a new name is not that strange. At least I think this is what's causing this.
I'm pretty sure I've fixed this as follows:
Hopefully, this was the final time I had to do that. So far, so good.
11-16-2020 02:53 PM
I too have had this vexing issue for a while, and agree that it is most likely the router changing addresses... I use an AirPort Extreme.
I just permenently assigned the IP that the printer is currently using to always be there for it... that way, nothing else can be assigned to it.
I also, re-installed the printer using the Canon supplied drivers (instead of AirPrint).
All I can do now is wait and see if it drops it again... I'll let you all know!
11-19-2020 10:00 AM
12-31-2020 07:38 AM
What fixed it for me :
* use a static IP for the printer at the router level
* use the same static IP for the printer in the printer settings (for my MF743C it is Network Settings > IPv4 Settings > IP Address Settings > Auto Acquire > OFF and add IP address below).
01-03-2021 01:20 PM
Gave it another try after a few more months of recreating printer definitions. Installed the latest canon drivers, applied @feax suggestion...
No success, after two days my mDNS Name was changed to "Canon-MF643C (dc:09:2a) (11) (dc:09:2a) (2)" instaed of just "Canon-MF643C" which I entered
01-17-2021 05:33 PM
I've got this same issue. ASUS router.
I have reserved DNS names/IPs enabled but I've decided to turn OFF DHCP in the printer settings and set a fixed IP.
Still appends a hex triplet to the mDNS/Airprint name.
01-18-2021 07:37 AM
Tried everything. Fixed IP with disabled DHCP still doesn't work (hex data appended still after a while).
Also tried with and without IPv6, with and without DHCP, with and without reserved DHCP lease on router based on MAC address, etc... Still fails. Nothing prevents the name to be changed after some time.
I can't believe Canon still hasn't fixed this obvious bug.
02-12-2021 09:23 AM
I have the same problem. It occurs whenever the printer is turned on/off and also when it loses network connection. I have tried every fix in the forum and none works. The only fix that works is to rename the printer (without the hex nonsense appended) in the AirPrint control panel in a browser.
Canon, please fix this!
04-04-2021 10:11 AM
Just giving an update following my post where I said I fixed that issue.
What I did :
* use a static IP for the printer at the router level. My router is a Netgate SG-5100. The static IP is outside of the DHCP range with a permanent ARP Table entry.
When I turn the printer on and off the printer's name doesn't change any more.
Since I made these changes 4 months ago the issue did not happen to me.
Hope that helps...
