02-28-2024 08:31 PM - last edited on 02-28-2024 09:15 PM by Tiffany
I've just made some changes to the network, including a new SSID and password. I went through the network settings on the printer - selected the SSID and very carefully typed the correct password. I've done this multiple times on 2 different printers (both are MF641CW) and both refuse to connect. Does anyone know if these printers have some kind of limitation on password length or characters? Or maybe it's our WPA mode... do they support WPA2/WPA3?
02-29-2024 12:29 AM - edited 02-29-2024 12:32 AM
Please tell us more about the router or routers you are using the printers with. brand/model.
The printer (MF641Cw) supports 2.4Ghz Wireless. WPA2/AES Encryption. If your routers are dual or tri-band and using the same SSID name for all broadcasts, this might cause connection issues.
Here's what you can try:
Use Unique SSID names for each broadcast (example) yournetwork2.4, yournetwork5G
Ensure you use WPA2 or WPA3/WPA2 to ensure backwards compatibility. WPA2 is very secure.
Temporarily disable the 5G broadcast, re-enable once the printer is connected to the 2.4Ghz.
~R5 C (1.0.7.1) ~RF Trinity, ~RF 100 Macro, ~RF 100~400, ~RF 100~500, ~RF 200-800 +RF 1.4x TC, BG-R10, 430EX III-RT ~DxO PhotoLab Elite ~DaVinci Resolve ~ImageClass MF644Cdw/MF656Cdw ~Pixel 8 ~CarePaks Are Worth It
02-28-2024 09:14 PM
Welcome to the forum!
So that the Community can help you better, we will need to know which version of Windows or macOS are you using? Is there an error message? Any other details you'd like to give will only help the Community better understand your issue. If this is a time-sensitive matter, click HERE search our knowledge base or find additional support options HERE
02-29-2024 02:19 PM
Thanks a bunch, Rick! We just upgraded from a crappy old consumer grade router to an enterprise-grade TP-Link system with 2 tri-band access points. Turning off 5 and 6 GHz bands didn't do the trick but creating a new SSID that's 2.4 GHz only did the trick. All of this is for a business so I really appreciate your speedy response!
02-29-2024 02:56 PM
Thanks for the feedback DonnyBahama. I have a tri-band 6G mesh system also. I created a dedicated 2.4Ghz band which currently hosts my printers also.
