06-04-2023
10:02 PM
09:50 AM
Hello, [Linux] MF/LBP Network Setup Tool Ver.2.31 is obsolete; and I cannot setup imageCLASS LBP6230dw to connect via WiFi. \
The Remote UI doesn't support WiFi setup neither.
I cannot install the utility on Debian 11.
Do you have an upgraded utility I can use?
Thanx
$ sudo apt install ./cnnst_2.31-1_amd64.deb
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
Note, selecting 'cnnst' instead of './cnnst_2.31-1_amd64.deb'
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
cnnst : Depends: libgnome-keyring0 (>= 0.6.0) but it is not installable
10-09-2023 08:12 PM
Did you solve it?
01-07-2024 01:11 AM
Yes I have also just run into this on Ubuntu 23.10
01-13-2024 09:48 AM
Had the same problem.
What's the solution ?
Do you have to build the driver from source ? but there is no make in the source folder.
Do you have to choose/download another driver ?
01-13-2024 09:21 PM
no I just gave up for the moment on printing my car registration, hopefully I don’t get pulled over 🙂
01-14-2024 10:11 AM
argh
It worked fine on linux on old systems (previous ubuntu, mint, fedora, debian). I will continue to search (and will tell you if I succeeded)
01-15-2024 08:08 AM
ok great ! thanks for updating
02-02-2024 10:51 AM - edited 02-02-2024 11:06 AM
#get libgnome-keyring0 fromhttps://old-releases.ubuntu.com/ubuntu/pool/universe/libg/libgnome-keyring/
sudo dpkg --force-all -i libgnome-keyring0_3.12.0-1build1_amd64.deb
sudo dkpg -i cnnst_2.31-1_amd64.deb
