imageCLASS LBP6230dw Can't connect via Wi-Fi on Linux
X0X0X069
Hello, [Linux] MF/LBP Network Setup Tool Ver.2.31 is obsolete; and I cannot setup imageCLASS LBP6230dw to connect via WiFi. \
The Remote UI doesn't support WiFi setup neither.
I cannot install the utility on Debian 11.
Do you  have an upgraded utility I can use?
Thanx
$ sudo apt install ./cnnst_2.31-1_amd64.deb
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
Note, selecting 'cnnst' instead of './cnnst_2.31-1_amd64.deb'
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
cnnst : Depends: libgnome-keyring0 (>= 0.6.0) but it is not installable
7 REPLIES 7
rsalcedo
Did you solve it?
ricardoAlien
Yes I have also just run into this on Ubuntu 23.10
flt
Had the same problem.
What's the solution ?
Do you have to build the driver from source ? but there is no make in the source folder.
Do you have to choose/download another driver ?
no I just gave up for the moment on printing my car registration, hopefully I don’t get pulled over 🙂
flt
argh
It worked fine on linux on old systems (previous ubuntu, mint, fedora, debian). I will continue to search (and will tell you if I succeeded)
ok great ! thanks for updating
finitelife
#get libgnome-keyring0 fromhttps://old-releases.ubuntu.com/ubuntu/pool/universe/libg/libgnome-keyring/
sudo dpkg --force-all -i libgnome-keyring0_3.12.0-1build1_amd64.deb
sudo dkpg -i cnnst_2.31-1_amd64.deb
