01-05-2018 11:02 AM
Hello, I recently changed the wifi setting of my network, we changed the network password, and now the printer is offline and I haven been able to reset it. I tried connecting it to my mac and going through the setup again, but it doesn't work, the wifi light blinks fast and the cancel button lights up, y restarted the router. I'm trying to follow this instructions here http://gdlp01.c-wss.com/gds/1/0300008421/01/PRO-10_PRO-100_NonPC_EN.pdf but I don't know what the access point is? How can I fix this?
Thank you
11-27-2021 03:14 PM
I need an easy fix. looks to complicated, please
11-27-2021 04:26 PM
I had to find my cable and connect it via usb. I cannot find my original set up disc, and I just cant get it done without it. Im lost. ugh
11-27-2021 04:31 PM
You can download all software from here. Don't need CD.
11-29-2021 02:13 PM
How can I order a new or replacement setup cd/disk for my pixma pro 100, please?
11-29-2021 04:05 PM
@coolvanstuff wrote:How can I order a new or replacement setup cd/disk for my pixma pro 100, please?
I don't know if Canon sells them, but even if you could it would be an 8 or so year old item.
The latest versions of all software are on the Canon support site.
11-29-2021 08:03 PM
11-29-2021 08:07 PM
11-29-2021 08:07 PM
Download / Installation Procedures 1. Click the link, select [ Save ], specify "Save As", then click [ Save ] to download the file. Memo : If you select [ Run ] ( or [ Open ] ) instead of [ Save ], the file will be automatically installed after it is saved. 2. The downloaded file will be saved in the specified place in the self-extracting form ( .exe format ). 3. Double-click the downloaded EXE file to decompress it, then installation will start automatically.
What link1?
All I get is this>>
p86I_win_pro_100-....exe
There is no thing to click run after thge install. I just want this to be wireless on My new ATT interent. I flat need lamens terms help. please
11-29-2021 08:49 PM
11-29-2021 10:17 PM
