blue tooth
vacsdr
where do I find the PIN for mi ip100 printer to connect it to my Samsung Chromebook?
1 REPLY 1
jrhoffman75
Founnd this on Amazon. It may help. I see the instructions say "Mac' but you should be able to substitute your equivalent PC terms.
1. Download the latest drivers for your printer from the Canon USA web site and install the package first.
2. Make sure the BU-30 is inserted into the the printer's USB port and the printer is turned on.
3. Open up System Preferences and select Bluetooth. Make sure bluetooth is enabled on your Mac.
4. On the bottom of the left panel, click on the "+" button to "Setup new device".
5. Wait for the Setup Bluetooth Assistant to find your printer. If it doesn't find the printer check that the printer is within 15-20 feet of your Mac and try again.
6. Pair with the printer. You'll see a message to enter "0000" that will disappear quickly. You won't need to enter anything.
7. You'll now be redirected to the Print and Fax panel. You won't see the printer listed (you have to manually add it).
8. At the bottom of the left panel in the Print and Fax dialog box, click on the "+" button to add a new printer. The Add Printer dialog box will be displayed.
9. At the top of the Add Printer dialog box, click on the "Default" printer icon.
10. You will see your printer in the printer list. In my case my printer is listed as "Canon iP100 series(D5:14:29)"
11. Select your printer then click on the "Add" button.
12. You're done. You should now be able to print to your printer via bluetooth.
