Where can I find the WPS code
Nicole8100
2 REPLIES 2
Tiffany
Moderator
Moderator
Welcome to the forum!
So that the Community can help you better, we will need to know the what model Canon printer.  Which version of Windows or macOS are you using? How are you connecting? What is the exact error message?
Any other details you'd like to give will only help the Community better understand your issue. The forum is not intended for immediate support. If this is a time-sensitive matter, click HERE search our knowledge base or find additional support options HERE
Greetings ,
WPS stands for Wi-Fi Protected Setup.  This is numeric code that can be set on your router if it supports this feature.  It not a very secure method of authentication since its complexity is only numeric.  Not every router supports WPS, so you don't need it to connect your printer to a wireless network.  Just use the Wi-Fi broadcast's SSID name and password to authenticate and connect your printer to your network.  We can provide more specific steps when you provide the model of your device.
