Trying to set up cloud print service imageCLASS MF753Cdw
user03895r7
I'm trying to set up the canon cloud printing service.   I get the message that it's not available in my region during setup.  I'm in Texas, USA.   The printer is a MF753C.   Is it available here or has it been discontinued?
Can you please direct me to the service (provide a link) or tell me what option in the application library you're using?
I'll be able to give you more feedback once I'm able to identify what it is that you're using.
Is this it?
Canon Cloud Printing Center https://share.google/5mMIM5VkqnOXicDYp
Cloud printing from the printer https://share.google/1YII1dGDxFSop4urD
I can provide additional assistance if you'll just guide me to what it is you are using.
9 REPLIES 9
user03895r7
I should mention that this worked a couple of years ago, but I can't edit my message, sorry.
Google discontinued cloud print in Dec 2020 with final termination in Jan of 2021.
However, I get the feeling you are referring to another function?  Are you trying to Scan to Email or do you want the ability to send emails from another device with attached documents and have them print on your MF753Cdw?  It sounds like the latter.  Let me know.  😉
I'm going to guess.  I believe this is the feature you're looking for.
It's called i-Fax and yes its supported.
https://oip.manual.canon/USRMA-7178-zz-SSM-750-enUS/contents/devu-fax-ifax.html
No, it was the cloud print I was referring to.   It sent me to a Canon page that said it wasn't available in my region.   I didn't realize that Canon was using Google.
Nope, I was asking about the Cloud Print.  didn't realize Canon was using google.
user03895r7
I guess no go for the Cloud Print via Canon/Google.   I'll probably set up universal print with M$.   They have it for a fairly low cost once you jump through all the hoops to get a business id from them.
What happened was that the printer was just replaced via the warranty.  Canon says you can still use the web service if you're already using it, which I was with the previous printer, but now they no longer are registering printers for the web service, and the warranty replacement printer would be a new registration. 😞
Is this it?
thank you for the urls.  That worked.  I'm not sure where the printer UI sent me to when I tried to set it up before.  The v8.01 firmware they just released mentions some fix for the Cloud print system, so that may have been it, also.
Spoke too soon.  I get to the point where I add my webservice registration code (I'm doing this through the remote UI) and it says it's not available in my region (the US) after I enter my registration code.   This is a Canon MF753c that I just had replaced by canon warranty service.
