05-18-2020 11:19 PM
I have a TS9020 on WiFi that will not wake up when print jobs are sent to it.
In order to print I must:
If I do not wake the printer manually, before printing, the print driver fails to detect that the printer is not ready and sends the output which dissappears into the bit bucket.
Ideally I'm looking to get the print driver to wake the printer, when processing print output but, if I can't manage that, detecting a printer not ready status would be an improvement over the currenbt state.
This is on PcLinuxOS . 5.5.10 with the Canon Driver: cnijfilter2 5.40
Thanks for any help with this.
05-19-2020 10:35 AM
Hi starrig,
You can check to make sure the auto power on setting is set to on and not off. Please follow the steps below:
Select Setup on the HOME screen.
Select Settings.
Select ECO.
Select Energy saving settings.
Check on-screen instructions and select Next.
05-19-2020 01:02 PM
I checked those settings:
Doesn't explain with printing does not wake it up but, at least it should provide a longer wait period before it goes to sleep?
Thank you
09/26/2023: New firmware updates are available.
CN-E45-135mm T 2.4 L F - Version 1.4.0
EOS 1DX Mark III - Version 1.8.0
EOS R6 Mark II - Version 1.2.0
08/18/2023: Canon EOS R5 C training series is released.
