02-05-2023 01:56 PM
Can not add the printer - with the message Apple does not support this - contact Canon. The printer worked great with my work laptop (DELL) but want this for home use. I've uninstalled and restarted it. There is a list of printers to add but this model is not on the list.
02-05-2023 07:49 PM
Looks like Catalina is the last supported macOS.
If you connect via USB looks like it should work as an AirPrint printer.
02-05-2023 09:44 PM
I tried this and the TS 202 is still not listed as an option. Appreciate the help!
02-05-2023 10:45 PM
Give Canon a call at (866) 261-9362
02-06-2023 10:24 AM
I've called that number multiple times and can not get to an agent for support. The automated system is not recognizing my phone number even though I set up a My Canon account. I guess I need to return this printer since it's been an exercise in frustration starting with the fact that the printer is not sold with a USB cable and when purchased at the big box retailer, they had none in stock. Not your problem, I get it, but Canon has made this ridiculously difficult to set up a printer.
02-06-2023 11:26 AM
Hi Lorihunter!
If you created your account here https://canon.us/3I2vZvU ensure you are calling from the phone number registered. If the issue continues, try the forget password option. If needed, our friendly support team can help. Give them a call at 1-800-OK-CANON (1-800-652-2666)
We hope this helps!
