03-12-2019 12:30 AM
For whatever reason, my Canon TR8520 printer has saved default connections for a wifi network that I don't want it connected to, but I can't manually connect it to the one I use.
I'm working on figuring out how to reset the wifi settings, or forget the network, or etc. from the printer's operation panel.
Any assistance is appreciated.
03-12-2019 09:25 AM - edited 03-12-2019 09:27 AM
Use the following instructions to complete the install.
03-12-2019 08:44 PM
From what I vaguely remember when I originally set the printer up 2 months ago, those instructions look like what I did then, and it was working fine until about 1-2 weeks ago.
I will look at the instructions on the page, and see if I am able to go through them, but IIRC, reecent attempts to adjust the wifi network have not been sucessful.
03-12-2019 09:18 PM
No, I already have the Canon quick menu installed on my computer. But there isn't a way through that to adjust the network settings.
Is there a way to reset the printer default wif network settings?
Or change the wifi networks the printer can detect?
03-13-2019 03:14 PM
Hi herblau,
There is a way to reset the wireless settings on your printer. Please follow the steps below:
You wireless setting on the printer has now been reset and you can connect the printer to your network.
03-26-2019 03:07 AM - edited 03-27-2019 05:04 AM
@herblau wrote:For whatever reason, my Canon TR8520 printer has saved default connections for a wifi network that I don't want it connected to, but I can't manually connect it to the one I use.
The steps to reset wireless settings are:
Go to settings menu from home screen,and then to device settings.Then go down and select on reset settings.And final step go to LAN settings and type yes.And then click ok and return to home menu.I hopeit helps.Regards myschoolbucks
