11-23-2021 07:52 PM
We have a canon TR8520 Printer. It has always been tempermental, to put it politely, and only worked wirelessly on a few devices. However we just changed our router, and while the Name and Password did not change, the printer no longer works on any device. I reconnected it to the wifi and it has 100% signal strength but when I try to find it on any device, it does not appear. Even when I search by IP address it does not exist, despite the router settings show the printer is successfully connected to the wifi. The device's OS doesnt seem to be a contributing factor as neither Android or Apple phones can find it, nor can Windows 10 or 8.1. I have tried to run the setup again ,but that cannot find it either so can't do anything. Neither has reseting all settings on the printer as I still can't find it.
Nothing online has helped as everything is either cookie cutter responses or issues connect the printer to the wifi and not the printer to the computer. If anyone has a way to fix this I am all ears.
11-23-2021 11:39 PM - edited 11-24-2021 12:19 AM
Maybe this will help.
Connect the printer to the wi-fi
Connect the windows 10 PC to the wi-fi
What is the IP of the printer?
What is the IP of the windows PC?
Windows PC
Start menu button
Type cmd, select the command prompt and press enter
Command prompt opens
at the prompt type >ping and the IP of the printer
Exmple
One of my printers uses 192.168.1.99
so
C:\Users\ItAdmin>ping 192.168.1.99
Press enter
Example of printer responding to ping command
Pinging 192.168.1.99 with 32 bytes of data:
Reply from 192.168.1.99: bytes=32 time=5ms TTL=255
Reply from 192.168.1.99: bytes=32 time=7ms TTL=255
Reply from 192.168.1.99: bytes=32 time=8ms TTL=255
Example of PC cannot communicate with printer:
Reply from 192.168.1.102: Destination host unreachable.
What can keep the computer from communicating with the printer
-Incorrectly configured network or router
-Windows firewall
-3rd party antivirus or internet security suite
Any additional information you want to provide about your network.. brand of router, model, etc. migh help. Seems odd that no devices can communicate with the printer.
~R5 C (1.0.3.1) ~RF Trinity, ~RF 100~400, ~RF 100~500, +RF 1.4x TC, +Canon Control Ring
~6D2 (v1.1.1) Retiring ~EF Trinity, others ~DxO PhotoLab Elite ~Windows10/11 Pro ~EVGA RTX 3080Ti FTW3 Ultra ~ImageClass MF644Cdw ~Pixel6 ~CarePaks Are Worth It11-24-2021 09:24 AM - edited 11-24-2021 09:32 AM
We have an Xfinity xFi 3rd Generation gateway, Model CGM4331COM. The Wi-Fi is 2.4 GHz with a WPA2-PSK (AES) security mode.
The printer is currently assigned to a Standard TCP/IP port and when I pinged it, I got:
(163 is the printer, 76 is my Pc.)
C:\Windows\system32>ping 10.0.0.163
Pinging 10.0.0.163 with 32 bytes of data:
Reply from 10.0.0.76: Destination host unreachable.
Ping statistics for 10.0.0.163:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
When I ran the setup, it did mention it needed to disable a block from the firewall, though I hope the setup would successfully do that.
11-24-2021
10:01 AM
08:35 AM
Some progress thank you.
Do you have a 3rd party antivirus program installed?
Are you using another router, extender or mesh system in conjuunction with the xFinity gateway?
Next step - Temporarily disable the windows firewall.
Start menu > type Windows Defender Firewall
When this opens, look on the left hand side of the screen (Nav Pane) , click turn off windows defender firewall.
Turn off for public and private networks.
Retest ping.
You can also try entering the printer's IP into your web browser.
~6D2 (v1.1.1) Retiring ~EF Trinity, others ~DxO PhotoLab Elite ~Windows10/11 Pro ~EVGA RTX 3080Ti FTW3 Ultra ~ImageClass MF644Cdw ~Pixel6 ~CarePaks Are Worth It12-20-2021 03:44 PM
Hi GetterOhNo,
Please turn your PIXMA TR8520 off.
Next, please disconnect the power cord to your router.
Wait 2 minutes and then reconnect the power cord to your router.
Once your router is back online, please turn your PIXMA TR8520 back on and attempt to print.
Routers connect all of the devices that you have together and also provide access to the internet. To keep each device unique, the router will assign each device an IP address. The device and it's IP address are saved in the router in what is called a "routing table". Destination host unreachable means that the router knows there is a device connected with that IP address, but does not know how to send data to it. That is caused by an issue with the routing table not being updated. Typically, turning off the printer, unplugging the router, reconnecting the router and turning the printer back on resolves this issue, as the routing table will refresh.
