11-27-2012 08:41 AM
how do you toggle from numbers to letters . I want to put in my password in and cannot get to letters MX430 printer
there is no mention and holding down number doesnt change it ????
11-27-2012 03:41 PM
I had the same problem! I finally had to call Canon - person on other end was VERY helpful and friendly, so don't be afraid to call them if you need to - I couldn't figure it out without calling them - but, I don't remember exactly how to do it now without having that "keyboard" up on the printer, but it involves using the "arrows", etc., - just play around with it - you'll get it. Once you figure it out...it's easy, of course!
11-27-2012 03:41 PM
11-28-2012 12:53 PM
Hello Zoomzoom300hp.
When you are entering the encryption key using the 'Standard Setup' method, please use the Tone or star (*) button on the unit. This will allow you to switch between uppercase, lowercase and number entry.
11-29-2012 05:17 PM
