12-27-2024
12:56 PM
08:04 AM
hi, brand new user to forum. Cannot find a thread covering this
Mac user, Macbook M4 Sequoia 15.2
Just purchased a Printer Pro-1100
Installed and updated firmware on printer 1.020
Installed latest Professional Print Layout
When finding the printer on initial setup, the software displays - this printer is not registered with PPL - exiting PPL (it finds the printer)
how can I get the PPL to see this printer - printer is connected on wifi and has printed a test print - just a word doc
12-28-2024 10:33 AM
Hi Ian.
Since you cannot print photos from Preview or CaptureOne the problem you are having would seem to be related to the printer and not PP&L specifically.
I noticed you said bonjour printer. Are you sure that the installed printer device is using the Canon IJ Series driver? Try deleting the printer and re-adding it. When you select the add icon wait until the Canon IJ Series version of the printer appears. It can take several minutes and will usually appear after the Apple AirPrint version of the driver appears.
12-29-2024 12:59 AM
Thanks John,
I uninstalled and reinstalled again today, and it seemed to do the trick. the PRO-1100 showed up when I launched PP&L and I am now able to print from it without any problem. I am not really sure of any difference but it works so I am happy and able to start testing!
thanks for all the help
Ian
01-01-2025 06:59 PM
My printer is working now, as well. I chose to uninstall the printer, reset all the settings to factory, turn off WiFi, LAN, and direct wireless, disable Bonjour (AirPrint), and connect to my MacBook Air M2 with a USB cable. When I added the printer, it found the ProGraf 1100 and the v.29 CUPS driver. I tried a first print of a JPG from the Photos app, and that worked fine. Then I opened PPL and opened a 16-bit TIFF that I had exported from Lightroom CC, and printed. No problems, no glitches.
My takeaway was that setup can go much more smoothly with a direct connection rather than wireless. Too many variables. USB has fewer variables. I can always attempt to set up Wireless and troubleshoot that later on, without wondering whether my new printer even works at all.
Thanks for help and encouragement.
-Byron
04-18-2026 02:12 AM
# Fix: Canon Professional Print & Layout Can't Find Your Printer After an IP Change (Mac OSX Tahoe fix)
## The Problem
If your Canon ImagePROGRAF printer's IP address changes — because you switched from Wi-Fi to Ethernet, your router reassigned it, or you changed your network setup — Canon's Professional Print & Layout (PPL) app will stop recognizing your printer. You'll see the old printer entry in PPL, but it can't connect. Trying to add the printer again doesn't work: PPL finds it, you click to add it, and nothing happens. The old dead entry stays.
This is a bug in PPL. The app stores your printer's IP address in a hidden file and never updates it.
## Who This Affects
Anyone using PPL with a network-connected Canon ImagePROGRAF printer (PRO-1100, PRO-1000, PRO-300, PRO-4100, and similar models). If your printer's IP has ever changed, this will happen to you.
## The Fix (5 Minutes)
### Step 1: Find Your Printer's Current IP
On your printer's touchscreen: tap the network icon or go to **LAN settings > Confirm LAN settings** to find the current IP address (e.g., `192.168.86.250`).
Alternatively, check your router's admin page for the printer's DHCP lease.
### Step 2: Open the Hidden Configuration File
1. Open **Finder**.
2. In the menu bar, click **Go > Go to Folder...** (or press **Shift + Command + G**).
3. Paste this path and press Enter:
~/Library/Application Support/Canon/DirectPrint/EntryPrinter/
4. You should see a file called **`EntryPrinter.xml`**. Right-click it and choose **Open With > TextEdit** (or any text editor).
### Step 3: Change the IP Address
You'll see XML that looks like this:
```xml
<?xml version="1.0" encoding="UTF-8"?>
<root>
<printers>
<printer>
<entryid>1</entryid>
<devicename>PRO-1100 series</devicename>
<printername>PRO-1100 series</printername>
<serialno>BBEL05xxx</serialno>
<portname>192.168.86.xx</portname> <!-- THIS IS THE OLD IP -->
</printer>
</printers>
</root>
Find the line that says `<portname>` and change the IP address inside it to your printer's **current** IP address:
```xml
<portname>192.168.86.250</portname> <!-- YOUR NEW IP HERE -->
**Change only the IP address. Don't modify anything else.**
### Step 4: Save and Relaunch
1. Save the file (**Command + S**).
2. Quit PPL completely if it's running.
3. Relaunch PPL. Your printer should now be recognized immediately.
## How to Prevent This in the Future
Since Canon hasn't fixed this bug, the best prevention is to **assign your printer a static IP address** (also called a DHCP reservation) in your router. This ensures the printer always gets the same IP, regardless of how it connects to your network.
Most routers support this under a setting called "DHCP Reservation," "Static Lease," or "Address Reservation." You'll need your printer's MAC address (found in the printer's network settings menu) and the IP you want to assign.
## Important Warnings
- **Back up before editing.** Before you change the XML file, make a copy of it (e.g., `EntryPrinter-backup.xml`) in case you make a typo.
- **Don't delete the DirectPrint folder.** If you delete `~/Library/Application Support/Canon/DirectPrint/` while troubleshooting, PPL may lose the ability to register your printer entirely — even after a full reinstall. If this happens, you'll need to restore the folder from a Time Machine backup.
- **This is not a macOS problem.** Your Mac's built-in printing (System Settings > Printers & Scanners) handles IP changes fine. This bug is specific to Canon's PPL application.
04-18-2026 09:23 PM
I agree USB is far less likely to cause connection issues.
