11-17-2025 06:33 AM
I've had to reinstall Photoshop Elements 24 on my PC after a reinstallation of Windows 11. Previously I'd used Canon Print Studio Pro as it provides a good printing interface. After going through the download process, I've been unable to get Print Studio Pro to open even though I see that a Print Studio Pro folder has been created. Each time I open the PSE photo editor I get a message that one or more plug-ins are unavailable. Looking at Help/System Info I see that four plug-ins from 4 different files failed to load. I had no problem with installing Print Studio Pro in the initial installation of PSE24, nor in PSE11. I've directed the download to the Adobe\Adobe Photoshop Elements 24\Plug-ins folder. I've also tried the installer's default of a Canon folder, though I can't find any Canon folders containing Print Studio Pro after doing this.
On advice given to another poster with a similar problem (PSE15), I have downloaded the latest printer driver for my Pro-100S but this has made no difference.
Thanks in advance for your help.
11-27-2025 06:43 AM
Is there someone from Canon who can help with this problem? As stated in my original post, Print Studio Pro downloaded and worked correctly when I installed it last year. Is it an issue with PSP having been updated to work with PSE25 and then PSE26, making it incompatible with PSE24? I understand that it is possible to download a stand-alone version of PSP if you own a Canon camera. Is it possible to download a stand-alone version of PSP to operate with my Canon Pro-100S printer?
11-27-2025 07:56 AM - edited 11-27-2025 08:03 AM
I just saw your other post and see you are running Windows 11.
The latest version of PSP for Windows is v2.2.4
This version shows support for PSE 24
Here's a download option from Canon Hong Kong.
Take a look at the release notes. They're pretty extensive.
Print Studio Pro Ver.2.2.4 (Windows) https://share.google/4VkrozMQ4pyuiIebz
Note, this is a plug-in 🙂
Downloads like this are typically available for printers, not for cameras.
~R5 C (1.1.2.1), ~RF Trinity, ~RF 100 Macro, ~RF 100~400, ~RF 100~500, ~RF 200-800 +RF 1.4x TC, BG-R10, 430EX III-RT ~DxO PhotoLab Elite ~DaVinci Resolve Studio ~ImageClass MF644Cdw MF656Cdw ~Pixel 10 ~CarePaks Are Worth It
11-27-2025 08:30 AM
Thank you for the link you provided. I've tried it and gone through the process, however on opening up Photoshop Elements Editor, I still get the message: "One or more plug-ins are currently not available on your system." Checking under Help/System Info I see the following:
Optional and third party plug-ins:
Canon Layout Plug-In for Print Studio Pro 2.2.4.0
Canon Print Studio Pro 2.2.4.0
Canon Print Studio Pro Export 2.2.4.0
PSP 2.2.4.0
Plug-ins that failed to load:
Canon Layout Plug-In for Print Studio Pro NO VERSION - - from the file “CNPSPPLayout.8li”
Canon Print Studio Pro Export NO VERSION - - from the file “CNPSPP03.8be”
Canon Print Studio Pro NO VERSION - - from the file “CNPSPP01.8li”
PSP NO VERSION - - from the file “CNPSPP02.8bf”
This what has been happening all along using the link for PSP provided for the Pro-100s on the Canon website. I can see that the Plug ins folder in PSE24 now has files where there were none previously, but PSP does not work. I can't work out why.
11-27-2025 08:35 AM
Hi Mark,
Let me ask my colleague jrhoffman75 (John) to look at this thread. He has the pro100 and uses it with LrC. He's very good with plug-ins.
11-27-2025 08:40 AM
Thank you Rick - much appreciated. It's now past midnight here, so I'll check in again tomorrow.
Cheers
Mark
11-27-2025 08:43 AM
He's here in the US with me.
I don't think Canon support will open until Monday.
11-27-2025 11:08 AM
My Windows PC is W10.
Since I can’t upgrade to W11 my primary computer is now my MacBook Air.
I have Parallels installed, which lets me run a virtual W11 computer on the MacBook
I just installed Ps and PSP in Parallels. Ps and PSP both installed but when I run the plugin installer it generates an error message that a compatible version of Ps isn’t installed, so I am not even getting as far as you. Sorry I can’t help.
In a different post it was stated that a standalone version of PSP could be downloaded if someone had a Canon camera. There is no standalone version of PSP. For later printers, like Pro-200, there is a new product called Professional Print and Layout which does have a standalone version. It is not compatible with Pro-100.
11-29-2025 06:58 AM
Hi John
Thanks for looking into my problem. At one point I used Copilot to try to get to a solution. After a few dead ends I was told that there was a standalone version of PSP available through the camera section of Canon's website. I thought I'd found the solution (though it may have been Professional Print and Layout) but I got to a point where I had to enter my Canon camera model and serial No. I don't have a Canon camera so couldn't proceed. However, from what you're saying PP&L would be incompatible with my Pro-100s. I'm hoping that Canon support gets to see my post and can come up with a solution. I found the PSP interface much easier to use than the PSE printing interface.
Cheers, Mark
11-29-2025 09:00 AM
Mark,
Support will not see your post here. You will need to open a case for assistance.
For US products:
https://myprofile.americas.canon.com/us/
For all others:
https://global.canon/en/support/
