12-04-2023 05:54 PM
Hello all,
I'm new to this body so please be patient. A pixma Pro-100 printer was recently donated to me (😁) and I have successfully connected it to my system and downloaded the driver. I have actually produced a print from it. I'm now trying to install the plug-in "Print Studio Pro" but am continually getting the error message shown below:
Now, I know for a fact that PS is installed on my system as I have an Adobe Creative Cloud account. The Print Studio Pro installer downloaded without any issues. No Windows apps were running when I tried to install Print Studio Pro. Anybody have any suggestions as to what I'm doing wrong?
I'm using a Dell XPS-13 with a Windows 11 (home) operating system.
Thank you.
12-04-2023 07:25 PM
Follow these instructions:
12-04-2023 07:25 PM
12-04-2023 10:01 PM
Yep, that did it. Don't know why the installer couldn't find the appropriate folders though.
Thank you.
12-05-2023 06:30 AM
@Richie_K wrote:Yep, that did it. Don't know why the installer couldn't find the appropriate folders though.
Thank you.
Adobe changed where plugins go for later versions of Ps.
12-15-2023 10:06 AM
Print Studio Pro "printer supported by this software is not found" problem MacOS solution.
For the MaccOS the Canon print driver installer automatically installs only the Airprint version which does not work with Print Studio Pro. I finally found an alternative way to install the proper driver using the Canon utility "Device Management Console". As follows:
Open Device Management Console (found in the Canon Utility folder.) The printer should show up in the window as well as the Connection: IP Address number.
Choose Manage Printer from the File menu.
At the bottom left of the Printer Management window choose Add Printer.
In the Add Printer window chose Auto (IPv4/IPv6) from the Search Method popup menu. Click "Search".
Check the printer box with the IP address in the list (either or both might work.)
Click "Add" at the bottom right of the window.
Try opening Print Studio Pro in Photoshop to verify yoru success!
