02-21-2020 10:35 AM
I just updated my firmware from 1.8 to 2.0 and when it was complete it wants a username and password for administration. I have no idea what this might be since I had never set one. Any ideas on what the default it?
02-21-2020 01:48 PM
The password was the serial number... finally found that on the Knowledge Base.
02-21-2020 12:19 PM
Hi wtripp08,
You can use the IJ Network Tool to change the password if it not known.
Please follow the steps from this page of the manual:
https://ugp01.c-ij.com/ij/webmanual/NetworkTool/W/3.4/EN/NWT/nwt_settings0700.html
02-21-2020 12:28 PM
Patrick, When I try to change it the program asks for the old password. That's the one I never set and I have no idea what it got set to after the firmware upgrade.
02-21-2020 01:04 PM
No matter what I try to do within that tool it wants the current password. Even if I try to do a Factory Reset it wants the Admin password. UGH!
02-21-2020 01:36 PM
Hi wtripp08,
You can try resetting your PIXMA iP8720 to the default, but please note, by doing so, you will have to reconnect your printer to your wireless network.
To reset your printer, please press and hold the RESUME/CANCEL button, then release the button when the POWER lamp flashes white 9 times:
https://ugp01.c-ij.com/ij/webmanual/Manual/W/iP8700%20series/EN/NTR/ntr_trouble0800.html
02-21-2020 01:48 PM
10-02-2022 04:13 PM - edited 10-02-2022 04:38 PM
Is there a default username?
EDIT: It ended up being ADMIN all uppercase.
