Pixma MG3620 USB connected properly but when I try to print, it shows OFFLINE
jadite47
ok, something as simple as trying to print via a USB cord has become extremely frustrating.  The only thing I did was change the ink cartridges.....nothing got moved or jiggled and yet now, when I try to print, it shows as OFFLINE.  I went through all the "DUH" steps to make sure it was connected properly and even restarted my PC but **bleep**'s still showing as OFFLINE.
I tried to start an email ticket but the form used to do that is not working......won't SEND and the drop down answers won't work either.
This printer has been a problem since day 1 and if I could afford to replace it, I would but it's fairly new and I am poor.
The only other thing that I have done recently is update windows with two critical updates so I hope that's not the issue.
Please help.....soon....I absolutely have to print a shipping label tonight!!
4 REPLIES 4
jadite47
well, I switched browsers thinking that might be why I can't get the help form to work but it's a NO GO on both Opera and Firefox
Jason
Whiz
Hi there!
You may want to try reseating the USB cable or trying a different USB port on the computer if possible. If it persists, can you let us know the version of Windows or Mac in use?
I've removed both ends of the cord to make sure they're in securely.....and changed the USB port that I used, too.  I'm not sure if I have another chord but will look but it went from needing new ink cartridges, me changing them to not working.  I cord could go bad within that amount of time?
I use Windows 7.
Hello.
Troubleshooting with our support group will be needed to narrow down the cause of your issue. Please contact our support group using the "Contact Us" link below for additional assistance.
Holiday
EOS R3 - Version 2.0.0
EOS R1 - Version 1.2.0
EOS R5 - Version 2.2.1
EOS R5C - Version 1.1.1.1
EOS C80 - Version 1.0.3.1
EOS R7 - Version 1.7.1
EOS R10 - Version 1.7.0
EOS R8 - Version 1.5.0
EOS R50 - Version 1.4.0
Powershot V10 - Version 1.4.0
Powershot V1 - Version 1.1.0
EOS R50V - Version 1.1.1
