06-15-2026 10:38 AM
Trying to connect wirelessly through the mobile app and everything works fine. The printer screen says press ok and when I do, it doesn’t connect and goes back to step 1.
06-15-2026 10:43 AM - edited 06-15-2026 10:44 AM
There is not a lot that can go wrong when using the Canon mobile app but it can. This is the guide and it has a couple of things to try (most are obvious) to get the devices to talk to each other:
If your PIXMA TS702a printer is not connecting after the final step in the mobile app setup, follow these troubleshooting steps.
To ensure you are following the correct setup process, here’s a quick recap:
| Step | Action |
| 1 | Open your smartphone's Wi-Fi settings. |
| 2 | Tap the network name starting with "Canon_ij_". |
| 3 | Open the Canon app and follow the on-screen instructions. |
06-15-2026 11:24 AM
I did all of those things. The app says communicating with printer and then says it couldn’t connect while the printer says connection complete, press ok
06-15-2026 11:31 AM
The printer requires a 2.4 GHz broadcast that uses WPA2 encryption. Can you please confirm your network meets these requirements?
The TS702a does not have a 5ghz radio and cannot connect to a 5ghz broadcast. If you have a dual or tri-band router that is using the same SSID network name for all broadcasts, try temporarily disabling any of the unsupported bands while making a connection then re-enable once the printer has successfully connected.
