11-11-2023
11:20 AM
11:33 AM
I purchased a Canon Pixma TS6420a recently after not being able to connect a Pixma MG 3620 to my iPhone 13 Pro. The new TS6420a printer is connected to the same wifi network, but when I go to choose the air printer the message always says "no air printer found." The new printer says it's connected. The online manual is useless as it recapitulates the same info as the hard copy instructions. My much older Pixma MG 3220 (on its last leg) is still found when I turn that printer on.
Canon blames the problem on Apple and Comcast. Any suggestions?
12-13-2023 11:05 AM
Do you have the Canon print app installed on your iPhone? If so, is the printer not detected there as well?
12-13-2023 04:13 PM
Yes, The App is installed on my phone. The Printer says it's on the network when I connect to my Wifi, but the new printer cannot be found on my iPhone 13 Pro. Using the App is no help. I even moved the printer next to the modem and the signal test was 100 %. Still no luck. Printer works fine when it's connected directly to my MacBook. I can only print wirelessly on my old MG3220 located in the basement.
10-09-2024 01:30 PM
Can you print to the printer from a computer or laptop through WiFi? I ask because I have the same problem BUT it seems that the printer is going into power saving mode, even after I turned it off via the printer menus. To print, I have to go to the printer, tap on the OK button to wake it up, and then I only have a few minutes before it goes back into sleep mode. Under the ECO settings, select Energy Savings Settings, then look at Auto Power Off, set it to Never, and Auto Power On, set it to ON. This is what the manual says to do but my printer STILL goes to sleep and AirPrint will NOT wake it up.
