PIXMA TR8620 WiFi problems with Eero mesh router
johnschult
Problem: New Canon TR8620 will not successfully perform WiFi setup. Neither mobile app or desktop app will configure WiFi correctly. Easy setup fails, manual setup does not prompt for password. Canon support offered no suggestions or solutions.
Network: eero Pro 6
johnschult
I had WPA3 enabled in Discover / eero Labs. I disabled it and performed WiFi setup again on the printer. Using the app again failed. I ended up having to do it manually and enter the password, but your mileage may vary.
When doing the WiFi setup, only connect to one eero router. Select the MAC address for the closest eero. After that I was able to select my SSID, enter password, connect.
I found the answer on Reddit. I find it ridiculous that no other devices on my network have a problem, but a Canon printer in 2020 can't figure it out. Sigh Smiley Frustrated
I hope this helps someone else!
5 REPLIES 5
johnschult
Exact same problem with the exact same printer. WPA3 prevent the printer from even asking for password.  Really wish I'd found your solution 3 hours ago! Would have saved me a lot of grief setting this up.
katigirl
OMG! I’d been searching for WEEKS! This solved my issue with j’y Legrand dimmer too! Thank you!!!
I just ran into a similar but worse problem with the Canon TR4720 printer. I did a normal setup attempt. The printer goes live, device (PC or phone) connects to printer, sets things up... the printer can't see my network.
So I tried picking just the MAC address for the nearby printer. No good.
I tried going to 2.4GHz mode. No good.
Finally, I unplugged all the the gateway node -- the printer's in the same room -- and that finally connected. It remained connected as long as it was up.
But eventually, the printer went to sleep. When I turned it back on again, it can't find the network. I have to take the network down again to get the printer up again, and that's good until the printer powers down.
My initial success had me send the box along to recycling, tragically, otherwise I'd return the stupid thing. I knew from experience with my Canon 6D that Canon was kind of stupid about WiFi (and GPS), but man, they've had a decade+ to learn a bit more. I have a dozen+ 2.4GHz-only IoT devices on the network with no complaints, all functional. I don't think it's eero, but on the other hand, I didn't have any problems at all with Google's mesh router, other than similarly simplistic UI/features... I mean, I could have solved this with a secondary SSID setup on my old Asus router in five minutes. Not that it should be necessary, but good networking tools take into account this sort of thing.
PatrickW9
I had similar problem. Here are the detailed steps I used (this is an expanded version of johnschult's fix – "only connect to one router"):
On printer:  LAN settings: Wi-Fi: Wi-Fi Setup: Manual Connect: (Choose Network)
Message appears: < Multiple wireless routers with the same name exist. > Click < Next > (OK)
Choose < Use one router only >
Message appears: < Refer to... check the MAC address... >  Click < OK >
Look at your mesh network management app to find the MAC address of the nearest router (MAC address is 6-field hexadecimal – e.g., 05:ba:96:5c:33:40). Choose that router on the printer.
Enter WiFi network password on printer; hit OK
Printer should connect; test by sending test print job to printer.
Hope this helps!
