06-14-2023 05:48 PM
I have had no success connecting this printer to my new mesh network. I can use it directly connected to any computer using the USB cable or I can connect to my network using a WPS setup but all my computing devices (desktops, laptops, Android phones, etc . . .) now use my home mesh network. I can see the mesh network SSID using the Canon setup software and whenever I enter the password it fails to connect. I have tried the setup several times and have ensured the password is correct by reconnecting devices using the password without failures.
The desktop computer I am using to set up the printer is running Windows 10 with the latest update. The printer has the latest firmware update installed.
06-14-2023 06:10 PM
The TS3322 is only capable of connecting to a 2.4Ghz broadcast supporting WPA/WPA2 encryption. What type (Brand/model) of mesh system are you using?
04-11-2025 01:10 PM
I had similar problem. My fix:
On printer: LAN settings: Wi-Fi: Wi-Fi Setup: Manual Connect: (Choose Network)
Message appears: < Multiple wireless routers with the same name exist. > Click < Next > (OK)
Choose < Use one router only >
Message appears: < Refer to... check the MAC address... > Click < OK >
Look at your mesh network management app to find the MAC address of the nearest router (MAC address is 6-field hexadecimal – e.g., 05:ba:96:5c:33:40). Choose that router on the printer.
Enter WiFi network password on printer; hit OK
Printer should connect; test by sending test print job to printer.
Hope this helps!
