02-01-2026
02:51 AM
10:00 AM
Good morning.
I bought this printer year ago and finally trying to set it up. I am trying to connect my pixma 4520 but it wont configure with my wifi system.
Whenever I try connect it to my wifi is gives error code 3441. Is there anyone who is able to help me with this?
02-01-2026 02:55 AM
Pixma TR4520 series
02-01-2026 10:42 AM - edited 02-01-2026 10:46 AM
Error code 3441 typically indicates a failure in the Easy Wireless Connect feature of the Canon TR4520 printer. This error can occur during the Wi-Fi setup process.
Retry Easy Wireless Connect
Alternative Setup Method
Turn on the Printer: Ensure your Canon PIXMA TR4520 is powered on.
Access Wi-Fi Settings: On the printer, press the "Home" button, then navigate to "Settings" and select "Wireless LAN setup."
Select Wi-Fi Setup Method: Choose "Manual Setup".
Select Network: Choose your Wi-Fi network from the list displayed on the printer.
Enter Password: Input your Wi-Fi password using the printer's keypad.
Press WPS Button: On your router, press the WPS button.
Select WPS on Printer: On the printer, select "WPS" from the wireless setup options.
Confirmation: Wait for the printer to confirm the connection. A message will appear on the screen once connected.
Print Test Page: Optionally, print a test page to ensure the connection is successful.
Check Wi-Fi Signal: Ensure your printer is within range of the Wi-Fi router.
Re-enter Password: If the connection fails, double-check the Wi-Fi password for accuracy.
Restart Devices: Restart both the printer and the router if issues persist
02-01-2026 12:07 PM
Greetings ,
In addition to the suggestions provided by my colleague, please tell us more about your wireless network.
The printer requires a dedicated 2.4 GHz broadcast that supports WPA2 encryption.
Please insure your network meets these requirements. If not, the printer will not connect.
