PIXMA MX922 Connection to New Network Problem
toobusytom
I have a new router and wanted to connect my MX922 to it. Watched the video and never got the screen where I could enter the password. Did get error message that the printer could not connect with the access point. Now what?
toobusytom
I finally just deleted all the oild software and then downloaded the drivers fresh. That did it for wired. Then was somehow able to get the wireless to work.
Thanks
2 REPLIES 2
ArthurJ
If the printer detects the router but does not prompt you to enter the wifi password, I would check with your internet provider to see if your router has WPA 3 enabled. If you have them disable WPA 3 and enable WPA2 and then you can enter the wifi password on the printer. Once that is done, you can enable WPA3 and the printer should still be detected.
As a work around you can also try disabling the ipv6 setting on the printer but this may not resolve the problem. Please click HERE for the steps.
toobusytom
Thanks
Friends and Family
