PIXMA MG2522 Installation Without CD
HugBug2023
I bought the Canon printer and scanner, I do not have a CD driver to be able to use the installation disk,  when I install it manually it says driver is missing.
Windows 11
5 REPLIES 5
SamanthaW
Moderator
Moderator
Hi!
To have a better understanding of your issue, please let everyone know the operating system on your computer, along with any other information you think might help the Community help you!
If this is a time-sensitive matter, please check out your other support options here.
Thanks!
Operating system64 bit, x64 based processor
windows 11 running in a mode
Greetings and welcome to the forum,
You do not need a CD drive to install the printer, drivers can be downloaded from the Canon support portal directly to your computer
https://www.usa.canon.com/support/p/pixma-mg2522#idReference%3Dsoftware-drivers
Just select your OS if not automatically detected.
I noticed above you typed windows 11 in a mode.
If this was a typo and you meant S mode, please let us know.
Yes it was suppose to have said S mode
Thanks for clarifying.  Windows S mode is an optional variant used to describe a locked down version of windows.  When this "feature" is enabled, it sometimes limits what you can install.  Its both a blessing and a curse in that it affords a ultra high level of security, by precluding what can be installed while the mode is enabled.
Us the link I provided above.  If you run into problems, see this link for disabling S Mode.
Switching out of S mode in Windows - Microsoft Support
