11-13-2025
03:49 PM
12:18 PM
I opened an Incident with Apple and they escalated to the experts. I was told this is a Canon issue and not a MacBook issue. MacOS doesn't use certs to print. I don't know how to proceed from here.
Thanks for any support you can offer.
11-14-2025 01:51 AM
It’s a Canon driver issue, not a macOS problem. After the factory reset the printer is now serving a new or invalid TLS certificate, and the Canon Mac driver pauses the queue when it can’t verify it. The fix is usually to remove all Canon drivers, reinstall the latest G7020 driver package from Canon’s site, and then add the printer using “IP → Internet Printing Protocol (IPP)” instead of AirPrint. This forces macOS to bypass the bad cert and restores normal printing.
11-17-2025 03:57 PM
Thank you for the response. I have followed your suggestions and I’m still receiving Invalid Certificate error. I don’t know if I should generate a self-signed certificate using the Remote UI or not. I don’t want to dig a deeper hole, since this printer works on our Win notebook, iPhones and iPads.
Thank you for any advice.
01-18-2026 03:43 PM
Facing the same issue. Did you find a solution?
01-18-2026 04:23 PM
Driver Issues: The Canon PIXMA G7020 is an AirPrint-compatible printer, which means it typically does not require additional drivers. However, after certain macOS updates, users have reported issues with compatibility.
Software Updates: Recent macOS updates, such as the Tahoe update, may lead to certification errors or connectivity problems with the printer.
Check AirPrint Settings:
Restart Devices:
Update macOS:
Network Configuration:
Following these steps should help resolve the certification error with your PIXMA G7020 on a Mac.
And this forum addressed this issue as well:
03-11-2026 11:37 AM
I am having the same problem with a G7020 and 2025 iMac that was recently upgraded to Tahoe 26.2. My MacBook Pro running Sequoia 15.5 works/prints fine. But the iMac on Tahoe is getting the Invalid Certificate error. I tried all steps above, including new Drivers, uninstalling all Canon drivers and trying AirPrint. No luck. Can someone let me know if a driver update is coming for MacOS 26?
