12-08-2023
09:52 PM
08:02 AM
James_C
I have the G7020 printer connected to my network via WiFi. I downloaded the latest G7020 software on my Windows 11 PC, and then I run the software and get to this point:
Printer was found
So the printer was found on the WiFi network. I then continue the installation process and it gets to this screen:
Connection failed
I've tried everything and Googled for an answer but cannot get the printer connected! I've even tried connecting the printer with a USB cable to get the network connection to no avail - it keeps coming up Connection failed.
Is there anything else I can do or try?
12-08-2023 10:42 PM
Happy Holidays,
Can you please tell us more about the network the printer is connecting to?
Router or access point is dual band, tri-band? 2.4Ghz/5G? Do all broadcasts use the same SSID name? Encryption type? (WPA2) (WPA3)?
12-08-2023 11:03 PM - edited 12-08-2023 11:06 PM
Hi - I have dual-band 2.5/5 Ghz eero 5 mesh router setup connected to my AT&T modem. There are 3 eero devices with the primary router being upstairs along with the printer in our office, and the other 2 eero are downstairs. All using the same SSID. The eero setup uses WPA2 encryption.
Also my Mac and phones have no issues connecting and printing to the printer, it’s just my Win 11 PC.
Let me know if there’s any other info you need.
Thanks!
12-10-2023 12:13 AM
No one else can assist or help?
09-12-2024 02:36 AM
Did you ever find a solution to this connection issue? I've been dealing with this as well after migrating to a new network.
