PIXMA G6020 wifi password entry not showing up
CMBrink88
I recently purchased a second hand Megatank Pixma G6020 Multifunction Printer K10496 and tried to connect it to my home Wi-Fi.
I did a manual search, it found my router, but when I selected OK to enter my password it went straight to trying to connect to it. When it failed, I tried it again and still did not ask for a password. I tried it on another Wi-Fi router that I know requires a password and it did the same thing.
1 REPLY 1
Anonymous
Not applicable
Troubleshooting PIXMA G6020 Wi-Fi Password Entry Issues
If the Wi-Fi password entry screen is not appearing on your Canon PIXMA G6020, follow these steps to resolve the issue.
Check Printer Settings
  • Power Cycle the Printer: Turn off the printer, unplug it for a minute, then plug it back in and turn it on.
  • Reset Network Settings: Access the printer's settings menu and look for an option to reset network settings. This can help clear any previous configurations that may be causing the issue.
Update Firmware
  • Check for Firmware Updates: Ensure your printer's firmware is up to date. Visit the Canon website to download the latest version if necessary.
Reconnect to Wi-Fi
  • Manual Connection: If the password entry does not show up automatically, try connecting manually. Go to the Wi-Fi settings on the printer and select your network. You may need to enter the password using the printer's control panel.
Additional Support
  • Consult the Manual: Refer to the user manual for specific instructions on connecting to Wi-Fi and entering passwords.
  • Contact Canon Support: If the problem persists, consider reaching out to Canon customer support for further assistance.
