01-03-2026
09:53 PM
03:40 PM
If I leave it on, after a while it will lose wifi connection. I have to go to the printer room and cycle printer power to get back online. I have very solid wifi, so it is the printer losing the connection. Is there a setting for this ?
Thanks,
01-04-2026 05:22 AM
Greetings ,
If your Wi-Fi signal is strong and stable, this likely has to do with DHCP settings. Login to your router's admin portal and look at your list of attached devices. Assign the printer a static IP address.
Once done, I suggest you uninstall and reinstall the printer as a TCP/IP printer on any systems you plan to use it with.
