06-12-2025
02:23 PM
05:28 PM
Tiffany
I have a USB B-A cable with good connections. Have not been able to get the installer to recognize the printer. For IP used 192.168.0.3 255.255.255.0 192.168.0.9
06-13-2025 06:48 PM
06-12-2025 02:26 PM
Thanks for joining the conversation, rsaunder!
So that the Community can help you better, we need to know exactly which Canon printer model you're using. That, and any other details you'd like to give will help the Community better understand your issue!
Thanks and have a great day!
06-12-2025 02:28 PM
3270 Mega Tank
06-12-2025 05:26 PM
IP addressing has no role in a USB connection. Starting from the beginning, how are you trying to install the printer?
06-12-2025 05:28 PM
Plug the printer USB-B to the computer USB-A. Run the installer. Can't find the printer.
The latest Windows update broke my ability to connect to my Brothers printer. I bought the Canon to replace it rather than wait for Microsoft. I wonder if the Canon interface is broken as well.
06-12-2025 10:07 PM
1. Does the printer, in its connection settings menus, have a place where you select USB or Network (WiFi or Ethernet)?
2. Does Canon say to connect printer to computer BEFORE installing software, or AFTER installing the software?
06-13-2025 09:28 AM
The printer has options for LAN setup, but there is no reference to USB. Software installation is not possible since the printer is not found.
06-13-2025 03:39 PM
Can't you just disable LAN?
06-13-2025 05:02 PM
This may be a simple question but did you try a different USB cable, they can go bad? My setup software also does not see my printer, but the Easy Print software does, and it was Windows that initialy installed the printer as soon as I plugged in the USB cord and powered on the printer.
06-13-2025 06:48 PM
It's fresh out of the box. I suppose that's possible.
