12-13-2020 01:09 PM
Now that Google cloud print is going away how do I get my MX922 to connect wirelessly. I have been through all the steps but the MX922 is not listed as a choice. Is there another printer that is close to the MX922 that I could select in its place?
Thank you
04-11-2021 11:57 PM
Hello, can yo send me the ppd file? I have an MX920 and cant seem to find a solution to print.
04-12-2021 12:23 PM
I sent you a PM.
I've also made the file info available on r/chromeos on Reddit. You can just search for "Canon MX922 PPD" and it should come up in the results.
04-12-2021 12:51 PM
04-12-2021 02:18 PM
I have the same issues on all three student chomebooks that used to print to my Pixma MX472. Any suggestion on how to get reconnected? I've tried the IP based method and it didn't work. Would the PPD file that everyone is mentioning work on my MX472?
04-12-2021 03:17 PM
Probably not. I'm no expert on this by any stretch of the imagination but it seems that it looks to make sure it's printing to the correct sort of printer that is in the PPD file. So you'd need to get the name of the printer that is being advertised and place that into the file just to even begin to test if they're further compatible (I'm guessing they're not without actually looking).
If you really want the file I can PM you the link (or you can search for it on Reddit) and you can try it as-is simply because you have nothing else and it won't hurt anything (you can just remove it).
04-30-2021 01:18 PM
05-01-2021 01:14 AM
I sent you a PM.
05-02-2021 09:45 AM
Can I also get a copy of the PPD? Thanks so much!
05-02-2021 10:42 AM
I sent you a PM as well.
05-02-2021 10:58 AM
Thank you!
