12-13-2020 01:09 PM
Now that Google cloud print is going away how do I get my MX922 to connect wirelessly. I have been through all the steps but the MX922 is not listed as a choice. Is there another printer that is close to the MX922 that I could select in its place?
Thank you
03-31-2021 04:58 AM
I sent you a PM.
04-06-2021 01:45 PM
I didn't get anything. 😞
can you send again?
04-06-2021 09:21 PM
If you have a chance to send the ppd file to me, that would be fantastic.
04-07-2021 04:52 AM
I sent you both PM's. Let me know if you didn't get them.
04-07-2021 11:37 AM
Got the PM and followed your instructions in Post #12 and now I have a printer again! Thanks!
04-07-2021 10:22 PM
04-08-2021 02:59 AM
04-08-2021 12:08 PM
Hi you,
I wanted to thank you one more time for your fix. You are great! Maybe you can help me with something else as you are a computer genius. I have a new Chromebox 4 with Displayport over USB C. I cannot get my monitor to sleep. It keeps looking for a signal. This did not happen when it was hooked up from DP to DP on my previous Chromebox. I just thought I would ask the genius. Thank you so much again. Best, Toolfriend.
04-08-2021 01:20 PM
Sorry, I don't have an answer for you off-hand. I've heard people having mixed results with sleep working so you might just have some of those with bad luck. I've heard some people say different cable configurations make the difference but I haven't tested this myself. Unfortunately, I haven't seen a solution to send your way.
04-08-2021 02:18 PM
Thank you for replying. I just wanted to pass it by you. I am still so thankful for your printer file. All the best
