02-03-2016 04:38 AM
In my old house my printer connected perfectly to WiFi.
I have moved house recently and installed the same router that I was using in the old house.
I've had to change the default IP address since my broadband supplier uses the 192.168.1.1 etc addresses. The router is now set as 10.0.0.1 as it's new local IP address.
I've tried the WPS set up which always fails. (It always used to work in the old house).
I've tried a manual set up but no joy.
It doesn't appear to pick up the SSID network so I've manually entered it together with an IP address.
It still doesn't connect.
Any ideas?
