07-28-2013 12:22 AM
I have just bought an mx920, beautiful printer I may point out, it worked well for the first two days but I cannot print as of today, I connect to the printer wirelessly and all my computers are Macs.
The printer is connected to the network properly and my computer shows that it has an active connectiong, but when I click print the printer goes to "in use" and then goes offline, and the Print Que says "Printer not connected"
I've tried connecting the printer to the network again, and I have restarted the printer along with my computers but it still wont work.
Please help
12-01-2017 12:42 PM - edited 12-01-2017 12:42 PM
The FIX is to go into:
Setup - Device Settings - LAN settings - other settings - TCP/IP settings - IPv6 - DISABLE
- Truong Vu
07-01-2017 09:21 AM
07-17-2017 11:08 PM
07-21-2017 10:16 AM
I keep having the same problem over and over.
When I have not used my printer for a few days, it decides to go off line - and nothing I can do gets me back online.
I cannot print as it give the following message:
Support Code : 300 The printer does not respond. Make sure that the printer is plugged in, powered-on, and properly connected to your computer.
what do I do?
Priscilla Larsen
07-21-2017 10:52 AM
02-07-2018 10:17 PM
this will probably be last canon printer. I need one that works when i send a document. this one radomly goes offline. doesn't matter whether using ios, pc, or android. have used canon printers for years aloong with cameras and quality doesn't seem to matter now.
02-07-2018 11:12 PM
04-15-2018 07:58 PM
04-16-2018 08:17 PM
Amazing. This fixed everything! Thank you so much!!! OMG......
04-17-2018 01:25 AM
