09-27-2018 06:35 AM
My father has a canon scanner Lide 110 that uses MP Navigator X.
That software does not longer work with macOS Mojave, it wont even start. That sucks.
Does anyone know of a good scanning software that works with Lide 110?
Preferably software that detects multiple photos and saves them individually as jpegs.
thanks.
12-26-2018 11:21 AM
There is no version of Navigator that works with Mojave. It is possible to operate the scanner with Mac's system preferences/ printer,scanner. But without editing capability. High Sierra versions do not work. Has Canon abandoned Mac users? Should Apple users look for a different brand of AIO printers?
12-27-2018 12:33 PM
12-27-2018 12:52 PM
open "system preference"s, click "printer/scanner" icon, click "scan" button (you should see your scanner listed), click "open scanner." Your scanner should warm up and give you an image with some options for size,color, resolution and location to put the file. There are no editing options.
12-27-2018 01:58 PM
12-27-2018 02:55 PM
12-27-2018 03:14 PM
12-27-2018 03:59 PM
12-27-2018 04:31 PM
I know for sure that Navigator 5x app does not work with Mojave. But the High Sierra printer and scanner drivers do work -- I'm using them now. So geting into guessing land.... I'd upload the newest or at least the High Sierra drivers. I'd delete Navigator. Then I'd delete all the installed printers and scanners. Then I'd reboot the Mac and in System Preferences add the printer and scanner as new. I think that has a pretty good chance of working normally for printing and for scanning using sys preferences as folks are describing today.
That said, I'm using an MG5320. I can't speak for other models.
12-27-2018 04:43 PM
01-07-2019 03:02 PM
Hey guys. I ran into the same problem with the Mojave OS update. But I think I found a solution, and got it to finally work.
I downloaded this updated MP Navigator here:
https://support-id.canon-asia.com/contents/ID/EN/0200572715.html
If you install it from the site, it won't work. It might even freeze the MP Navigator application on your computer, causing you to hard-shutdown to get out of it.
1.) Uninstall all MP Navigator applications from your Mac. Delete them.
2.) Go to https://support-id.canon-asia.com/contents/ID/EN/0200572715.html and download the updated software, and install.
Make sure your Mac is purged of all previous versions of MP Navigator before you install the new one. After the new one is installed, locate it inside your Mac's Applications folder, and it should work.
I hope that helps!
