imageCLASS MF644Cdw - Shows Offline from MAC
kaushikn
I have been struggling to get this printer to work consistently on my network from my MACs. Most of the times when I try to print, I get an error.
Opening the Settings --> Printers and Scanners --> Canon 644c,
The banner says that the printer is offline.
Under the print job I get the message Priner - Unable to find printer
  • The printer is on
  • The printer is close to the wifi router
  • I am using a reserved ip address for the printer (so that I have the same ip each time)
  • I can access the printer from the browser using the ip address
  • I was able to print from a moblie phone
  • I can scan from the Canon Print Business mobile app
  • I have installed the latest drivers from the support site on the PCs
  • I have tried to use the Airprint driver as well as the Canon Support site drivers
None of the macs can consistently print using the print function.
Anyone else face the same problem?
35 REPLIES 35
VideoGuy
I have the exact same issue with a Macbook Air with a MF641Cw !! We have removed and reselected the printer many many times as we thought that this sometimes worked.  Right now, I am installing the latest firmware update - something about a monitoring server, related to proxy authentication - whatever that is.  We can't be the only ones having this problem and its a serious one!
upnorthwi
Exactly the same problem. I have the same situation. The printer will occassionally print but it takes at least 10-20 minutes for the Macbook to find it. Often it doesn find it at all. The PC connects and prints just fine. I have been at this all day. Very frustrating
Hector
Hello kaushikn,
If the Macs keep losing connection while other devices are still able to communicate, it could be caused by signal strength or a network communication issue. If the printer is on WiFi, ensure the MF644Cdw's signal strength is at least at "Good."
<Status Monitor>  <Network Information>  <IPv4>  Select the setting to view  Check the settings
If the signal strength is poor, you can try moving the printer to see if it gets a better signal. If the signal strength is good, you can try refreshing your network connections by unplugging your router from the power for five seconds. Once the network is back up, you can try printing again to see if it responds from the Mac.
To provide additional information or to provide other options, we would need some additional information. If you could reply to the message with the information below, we would be happy to assist.
  1. What version of the Mac OS are you using on your computers?
  2. When you are unable to print, are you unable to scan from the Mac as well?
Hector: Thanks for the advice but I'm still having the same problem. The signal strength is strong (same room as router).
The Mac won't wake up the printer from sleep mode. I just get an error: "The printer may not exist or is unavailable at this time." One must physically walk to the printer, turn it off and on, and print.
I haven't tried scanning yet. I will try that if I can get the printer to work.
Mac OS 11.1.
FWIW, after I installed the latest drivers/firmware, I couldn't locate the printer at all from the MAC.  I forget the option to do this on the MAC, but I knew the IP address of the printer as I had dedicated it on my router.  I told the driver to use that IP address - low and behold it worked and I've haven't had a problem in two weeks!  Fingers crossed.  Hope this helps.
Hi Hector -
Thanks for responding.
  • The network connection is Good
  • I've restarted both the printer and the mac multiple times
  • Till recently, I was on OSX 10.15.7. I had the issue then. Last week I upgraded to Ben Sur. I still have the issue
  • Often times both printing and scannig are impacted. 1-2 times I noticed that the printer was offline and scanning was possible
  • Note that this is a shared network printer
  • Sometimes I scan from one PC and then when I try to scan from another, it fails. Then I cant scan from the first PC either
kaushikn
Same problems. No help from Canon. Today is my last day to file a return for the printer. I have opted to send it back and purchase something else. I will not forget what a terrible experience this was.
TGA516
I have had this same issue since day 1 with this printer. It consistently works fine from my Windows systems but has always failed to work with any of the household Mac computers (2 Mini’s and 3 MBP’s) and the common denominator is the Mac driver. We have deleted and reinstalled the driver so many times it makes my head spin and Canon support has just pretended they know nothing of this issue and it’s never come up before. It has persisted through several Mac OS/X upgrades and is beyond frustrating.
My network is mesh and solid throughout the house; I can print from my Windows machines from anywhere and Macs nowhere.
I'm having the same issue with my brand new MF743Cdw on two different versions of MacOS (11.2.1 and 10.15.7)
One difference with mine is that the printer is connected via Ethernet, not WiFi, so there's no way it's a WiFi signal issue.
I have no issue setting up the printer, but it goes offline after the printer goes to sleep and the Mac can't wake it up to print. What's really odd is that the scanner still works even though the printer says it's offline. I can switch to the scanner in Settings > Printers & Scanners. But even scanning something doesn't bring the printer online.
I've tried resetting the printing subsystem and I've removed and readded the printer numerous times.
Holiday
EOS R3 - Version 2.0.0
EOS R1 - Version 1.2.0
EOS R5 - Version 2.2.1
EOS R5C - Version 1.1.1.1
EOS C80 - Version 1.0.3.1
EOS R7 - Version 1.7.1
EOS R10 - Version 1.7.0
EOS R8 - Version 1.5.0
EOS R50 - Version 1.4.0
Powershot V10 - Version 1.4.0
Powershot V1 - Version 1.1.0
EOS R50V - Version 1.1.1
