02-08-2024 07:04 PM
I have windows 11 and when Installing the MFD drivers from the Canon website I get the message “Could not install the scanner driver. Try to install again.”
The print drivers install with no problem. I've deleted all Canon software and devices and retried with no success. From related fixes on this site, I've tried saving the install file in a separate folder and starting the computer in Selective Start Up. I've also disabled all Microsoft and Bit Defender antivirus and firewall protections.
I'm hoping someone will have a solution that will allow me to use the scanner.
02-08-2024 07:22 PM - edited 02-08-2024 07:24 PM
Greetings ,
The scanner driver is part of this package.
https://pdisp01.c-wss.com/gdl/WWUFORedirectTarget.do?id=MDEwMDAxMjA1MDAx&cmp=ABR&lang=EN
When you run this package, one of the first prompts will tell you that it needs to create an exception on the Windows firewall. Click yes for that. This happens behind the scenes, but if you want to know what it does, it adds an exception for "MF drivers" on the Windows firewall under private networks.
The next option will give you a choice for the driver you want to install. Since you've already installed the print driver and MF scan utility uncheck the first two boxes. Just leave the third one checked, scanner driver. Once this completes, you can open the MF scan utility from the start menu. It displays the printer selector which if you only have one installed, you don't need to select anything with all of the scanners options. It's basically the enabler for the MF scan utility. Let me know how it goes 😉
02-08-2024 09:13 PM
Thank you for the suggestion, however I still get the message “Could not install the scanner driver. Try to install again.”. I have disabled Windows Defender Firewall and the Bitdefender Firewall, so they are probably not causing the issue. I didn't get a message asking to create an exception but maybe that's because the firewalls are disabled.
02-08-2024 10:31 PM - edited 02-08-2024 10:47 PM
I'll need a little time to look more deeply at this. I have access to the GravityZone Admin Portal but don't recall if installing BD on a endpoint leaves the Windows Defender FW enabled. I don't think you need two software firewalls, and actually it could cause a behavior like this. I know you disabled both, but the process might be monitored.
This is a tool I've used frequently in the past with windows 10. I don't know if it works with W11, but suspect it might. It won't hurt your system at all so feel free to try it. It works for both install and uninstall of problematic software.
Fix problems that block programs from being installed or removed - Microsoft Support
Are you having any issues with the self-extracting .ZIP file? (Note my reference is for the 656Cdw example)
If so, rename its .exe extension to .zip. Right-click to extract it and run the setup.exe in the ...drivers\x64 folder
If not already done, also try downloading a fresh copy of the installer from the support portal. This looks like an issue in your software environment, so the above might not help, but it won't hurt to try.
Next step would be running System File Checker from an elevated command prompt. Note that's a forward slash / after sfc.. then press enter. We want "no integrity violations found". If they are, a reboot should resolve. Then run again.
02-09-2024 05:25 PM
I uninstalled Bitdefender AV program and turned off Windows Defender Firewall. I could not install the scanner driver even with a new download.
I tried getting the troubleshooter you mentioned but could not download it. I got the following message.
My system will not run the command prompt you suggested, I got a message "Access Denied".
Maybe something in the results I got will help point to a possible solution.
09-19-2024 10:01 PM
I am having exactly the same problem under Window 11.
"Could not install the scanner driver. Try to install again"
09-19-2024 10:41 PM
To confirm, you have a MF642Cw correct?
Which driver package are you having issues with?
[Windows 64bit] MF644Cdw/MF642Cdw MFDrivers (Generic Plus UFR II / Generic FAX / ScanGear)
[Windows 32bit & 64bit] MF Scan Utility Ver.1.21.0.2
09-19-2024 10:59 PM
MF644Cdw
Latest driver from Canon:
MF642CMFDriverV6405W64.exe
Windows 64 bit.
Cleared all old drivers, packages, anything I could find etc.
Can print fine, just not load scanner.
Errors if I try load scanner. No have not yet re-installed MF Scan Utility
""Could not install the scanner driver. Try to install again"
Was working fine until recently - suddenly lost access via wireless - so switched to wired.
Guessing it was after a recent W11 update, but not sure.
Installed on LAN.
I still can scan to usb, and carry memory stick to computer.
Problems is that it was working for a long time, no issues, and then when I needed it, printer, scanner, everything gone. Wish I could be more helpful.
Murphy's law in play - died when I needed it.
09-19-2024 11:07 PM
Rick,
FYI - I did try the "GPlus_UFRII_Driver_V300_W64_00" driver - didn't help.
Thanks,
Cedric
01-10-2025 11:03 PM
Anyone find a fix for this? I'm having the same exact problem. Very frustrating.
