08-25-2025
12:21 PM
02:25 PM
The MF Scan Utility has no ability to shrink or resize. Been that way since day 1.
Has no - or box to shrink. Only thing in top right hand corner is the X to kiil the APP.
Should be able to shrink or resize at will.
Anyone else experience this?
Is the MF Scan Utility the only way to start a scan session?
How do you contact support to suggest a software update to the MF Scan Utility?
Everything else is fine with my MF465DW printer.
Can't believe Canon created a scan utility without the ability to scan or shrink.
Thoughts please.
08-25-2025 03:31 PM - edited 08-25-2025 03:31 PM
Greetings
MF Scan Utility - This is expected, it's not an oversight.
Did you install ScanGear?
This is what you would use to select a custom output size.
08-26-2025 06:39 AM
Scangear was installed during the entire install process.
However, I have no Icon for SCANGEAR.
I hav e an icon for the MF Scan Utility which when opened,I click on SCAN and then
SCANGEAR opens up.
Seems a little backwards to me.
Also, most screens from apps on windows always have the buttons on the top right side
of the pop up.
08-29-2025 02:35 AM
You don't have the ScanGear option in the MF Scan Utility?
08-29-2025 06:00 AM
I have the screen you are showing, but it is not resizeable.
Because of poor vision I have increased the text size on my monitor. I do have the Scan Gear button
on that screen, but that screen should be made sizeable and shrinkable.
