04-17-2020 01:47 PM
04-18-2020 11:40 AM
While possible, its not usually a good idea to use two different connection types. Pick one, USB, ethernet or wireless.
The latter 2 will give you the most options allowing any device connecting to the same network the ability to print.
Wireless:
The printer can only connect to a 2.4Ghz broadcast. Have you verified a 2.4 Ghz network is available?
What troubleshooting steps have you performed?
Have you restarted the router?
04-28-2020 03:28 PM
Hi Haykay.
If the router has been changed or reset, you will need to perform the wireless setup once more. If the MF726Cdw is unable to see your network during the wireless setup, double-check that your access point is set to broadcast its presence; refer to the Access Point's documentation and support.
If this answered your question, please click the Accept as Solution button, so others might find the answer.
04-28-2020 04:13 PM
04-28-2020 04:14 PM
05-07-2020 03:14 PM - edited 05-07-2020 03:15 PM
Hi Haykay.
Damage caused by percussive maintenance is not covered by the warranty.
Try moving the printer or router so that they're both at least ~ 2 ft apart. If they're too close, it can cause signal noise (like they're shouting at each other without listening).
Something else to try is to enable the printer's Direct Connect mode, and check if the computer can find the printer's broadcast network. If the printer's Direct Connect network can be found, then the printer's WiFi components are working correctly, and the problem is somewhere in the router settings, or something is intefereing with the wifi between the printer and the router. You may also want to double-check that the router hasn't been set to blacklist the printer.
If you're unable to move the printer and router apart, you can try using a direct Ethernet connection (Cat 5e or 6 cord). Directions for connecting to a wired network may be found HERE in the online manual.
