06-06-2022 01:14 AM - last edited on 11-07-2023 09:30 AM by Danny
Hello together,
im proud owner of a Maxify MB5150. Printing works fine so war but im not able to scan to a network folder.
My goal is to scan to my Synology NAS. I enabled SMB1 (does it really only support SMB1?), permissions on NAS are enabled for the destinated folder, user and password are correct.
So inside the Quick Utility Toolbox i find the network folder but when i set all up I always get the error:
"No connection to the folder. Check the settings."
The user and password is correct for 100%, i even changed it to a very simple one. I have the same problem when i try to scan to a shared network folder on my computer (also smb1 enabled).
Any other important settings im missing?
As alternative, is it possible to scan to a defined folder by using USB? I need the scanned PDF files in a special folder to be processed by paperless.
Thanks in advance
11-23-2023 04:28 PM
Hi, not sure if this is still an issue for you but I just registered to tell you that I had to change the SMB settings in my NAS to include SMB3 too. Then it worked without the need of activating the NTLMv1
hope this helps if you still have issues. My printer is a GX7050
Cheers
06-06-2022 08:22 AM
Welcome to The Canon Forums!
We appreciate your participation, though we need to let you know that your product appears to be a model that is not supported by our team here at Canon USA. While the community is welcome to chime in, the Canon Community Forum is hosted and moderated within the United States by Canon USA. We are only able to provide support for Canon products manufactured for and used within the US market.
If you live outside the United States, please click HERE and select your country to find support in your part of the world.
11-05-2023 08:56 AM
Hello phenix90,
did you solve your problem? I have the same problem too.
Thanks, Martin
11-05-2023 09:19 AM
Hey,
i had to enable smb1 in my synology nas and additionaly the NTLMv1 authentification under SMB advanced settings. With this setting im able to scan onto my nas in any desired folder. Should be no issue for a local network.
11-06-2023 02:04 PM
Hello,
thank you very much, unfortunately this cannot help me 😞 , again this unpretty message "No connection to the folder. Check the settings." I have Synology 718+ and fw7.2.1. Im close to break ntb :).
11-23-2023 04:28 PM
Cheers
11-25-2023 05:36 AM
Yeeeeeeeeeeeeeeeeeeeeees 😀 It will help. Thank you very much. 🍻 or 🥂
12-04-2023 01:27 PM
hi all! same problem here, but the solution form user Cicciopaolo does not work. in my nas logs i cannot even see a connection attempt. even if firewall is turned off. nas can be pinged by the computer, where quick utility toolbox is installed...
any other suggestions? i habe a synology ds 218+ with dsm 6.2.2
thx in advance snIP3r
12-04-2023 03:53 PM
I also could not see any connection attempts from the sinology log.
Below the settings I have. I also have the 218+ but the DSM version is the 7.1.1
Before instead of SMB3 it was SMB2 (I think as default)
12-11-2023 01:19 AM
I tried the settings you suggested after upgrading to Version 7.2.1 - no success 😞 I cannot reach the folder. But i am wondering why you do not see any connection attempts in synology log?
